how to take off ef sedan dash????
Old Jul 14, 2008 | 05:56 PM
EGKREW's Avatar
Default how to take off ef sedan dash????
dose any one have the blueprints of how to take off a dash from a ef sedan . or a pic of where all the bolts are at?
Old Jul 14, 2008 | 06:16 PM
EGKREW's Avatar
Default Re: how to take off ef sedan dash???? (EGKREW)
help me out
Old Jul 14, 2008 | 08:28 PM
EGKREW's Avatar
Old Jul 14, 2008 | 09:18 PM
EF9yee's Avatar
How about you just do it and find the screws yourself, im pretty sure nobody here has a write up about the location of every screw. I did it myself and found out it wasn't as hard as i thought it would be.
sirjmj's Avatar
theres should be 3 bolts one on each side of the dash next to the vent, and the other one is in the middle of the dash but there a little cover over it, use a flathead to remove it, then a 10mm to remove the bolts, i think it should be the same the ef hatch for the dash, i took mine off too paint it.
Old Jul 14, 2008 | 09:24 PM
EvanFullwood's Avatar
yea pretty much what sirjmj said, there are a couple more bolts/screws like for the "center console" peice i believe, i cant really remember.i have a crx dash in my sedan. It's one of those things where you do it onetime and its like "oh.....****", and its easy after that
EGKREW's Avatar
Default Re: how to take off ef sedan dash???? (sirjmj)
Old Jul 15, 2008 | 12:52 AM
My_EFsedan's Avatar
8/10mm and screw driver
-there are 1 10mm on each side of the dash under the vent
-there is 1 10mm at the bottom of the center console where it goes to the chassis (take off the center console)
-there is one 10mm in the middle if the dash where it meets the windshield under a small 1x2.5 panel
-remove the cluster and there are 2 screwdriver screws (im sure there are two)
-there is 1 8mm/screwdriver on the right side of the glove box (the bottom one) where it is bolted down to an L shaped bracket to the chassis
-under the steering rack theres that big black bracket thats over the fuse box. 4 10mm remove that to make life easier when taking the dash out
i mean if its still stuck use common sense and find out thats holding it..
when i put my dash back in i only bolted the 2 on the side, the center console, the windshield and the glove box so later if i remove it again its easier and no, it does not wobble when i drive or race.
Old Jul 15, 2008 | 05:09 PM
EGKREW's Avatar
Default Re: how to take off ef sedan dash???? (My_EFsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">8/10mm and screw driver
when i put my dash back in i only bolted the 2 on the side, the center console, the windshield and the glove box so later if i remove it again its easier and no, it does not wobble when i drive or race.</TD></TR></TABLE>
sh!ft
Sep 24, 2009 08:36 PM
lance_dc2
Jul 9, 2009 09:59 AM
91Hatcher
23
Dec 22, 2008 12:39 PM
scuffywin
Jun 28, 2007 12:51 PM
JDM_EK_JOE
Feb 1, 2006 02:53 PM
