Fast SFWDers whats your intake air temps
Old Jul 14, 2008 | 05:07 PM
lwct100's Avatar
Default Fast SFWDers whats your intake air temps
What are your max temps ( air to air intercooler) and how much boost are you pushing and the temp at the track?
also Is there any general rule to how much you lower your temps to how much H.P you gain?
Old Jul 14, 2008 | 07:13 PM
tony1's Avatar
Default Re: Fast SFWDers whats your intake air temps (lwct100)
At the TTS, at 35psi i saw 240 deg compressor outlet temps, 111 deg at the throttle body, and i believe it was in the 90's ambient temp.
Old Jul 14, 2008 | 08:35 PM
Antilag's Avatar
Default Re: Fast SFWDers whats your intake air temps (tony1)
I saw 126 degree temps at the throttle body @ 41psi with ambient temp of 99.
Old Jul 14, 2008 | 09:05 PM
st00pid's Avatar
Default Re: Fast SFWDers whats your intake air temps (Antilag)
I just checked the logs on Dave Aiwase's CRX. He has an S366 with a crappy old tube/fin core IC and at the same event tony was talking about we saw 154 degrees at the top end of the track at 38psi.
Chuck P's car has a precision 825 IC and was at 109 at 23psi on a 10.2 pass the same day.
Old Jul 15, 2008 | 04:22 AM
SPOOLINmatt's Avatar
Default Re: Fast SFWDers whats your intake air temps (st00pid)
35 psi on mine yields about 115-118 at the TB. 85-90 degree days on average.
Old Jul 15, 2008 | 05:11 AM
tony1's Avatar
Default Re: Fast SFWDers whats your intake air temps (SPOOLINmatt)
How many of you guys are running Honda temp sensors?
Old Jul 15, 2008 | 05:23 AM
vtekthis's Avatar
i see 112-115 at +/- 40 psi, 85-95 ambient but feels like 120 lol
with a gm sensor.
i dont have any data before the IC, but i can tell you it works
Old Jul 15, 2008 | 05:43 AM
lwct100's Avatar
Default Re: Fast SFWDers whats your intake air temps (vtekthis)
Im running a stock temp sensor , at the big end of the track I always seem to see around 145 to 150+ degrees on a hot day around 38 to 45 psi.
Old Jul 15, 2008 | 05:47 AM
tony1's Avatar
What intercooler and turbo setup?
Old Jul 15, 2008 | 07:26 AM
airwalk07143's Avatar
he is running a precision 72gts turbo and a treadstone vertical intercooler.
Old Jul 15, 2008 | 07:59 AM
boosted hybrid's Avatar
Default Re: Fast SFWDers whats your intake air temps (airwalk07143)
On a garrett bar and plate 18x12x3.5" core with a 42r with a 1.28 a/r housing, 40psi was seeing 145-150 degrees on a mid 90 degree day. Car was using a GM air temp sensor in the charge pipe near the throttle body. Lowered air temps with air scoop to turbo inlet by 10 degrees in same condition at the next race.
Old Jul 15, 2008 | 12:28 PM
B18c1turboedEK's Avatar
Default Re: Fast SFWDers whats your intake air temps (boosted hybrid)
Where do you guys run your IAT sensor, before the throttle body? or in the stock location on intake manifolds?
Old Jul 15, 2008 | 02:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">How many of you guys are running Honda temp sensors?</TD></TR></TABLE>
I am but if you could direct me to a better sensor, Id like to see another option.
Old Jul 15, 2008 | 02:35 PM
tony1's Avatar
If you have a honda ecu, you're SOL as far as i know. If you have a standalone then you should be able to set the cal for different temp sensors. The GM sensor is actually pretty good and cheap. Bosch also has some nice stuff as well as a fast response temp sensor. A bit pricey, but really nice.
Old Jul 15, 2008 | 02:58 PM
turbotypeR@SPEC's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">If you have a honda ecu, you're SOL as far as i know. If you have a standalone then you should be able to set the cal for different temp sensors. The GM sensor is actually pretty good and cheap. Bosch also has some nice stuff as well as a fast response temp sensor. A bit pricey, but really nice. </TD></TR></TABLE>
the s300 has two extra 0-5v inputs that you can calibrate and name whatever you want it to be
Old Jul 15, 2008 | 02:59 PM
tony1's Avatar
Default Re: Fast SFWDers whats your intake air temps (turbotypeR@SPEC)
Works great for pressure sensors, won't work for temp sensors.
Old Jul 15, 2008 | 03:01 PM
are all the honda sensors created equal, newer or older? obd2 or obd1? Apparently i am SOL using my s300. lol
Old Jul 15, 2008 | 03:04 PM
tony1's Avatar
I've heard you get better results by relocating the temp sensor to an area that won't heatsoak so bad, but at the end of the day they all have slow response times. From the data i have, the honda temp sensor is about 12 seconds behind the GM sensor on the track, pretty much makes your temp compensations worthless.
Old Jul 15, 2008 | 03:14 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Works great for pressure sensors, won't work for temp sensors. </TD></TR></TABLE>
plx makes a temp sensor that is 0-5v. wouldn't this work?:
http://www.plxdevices.com/products/sm/ait/
Modified by turbotypeR@SPEC at 6:20 PM 7/15/2008
Old Jul 15, 2008 | 03:21 PM
Have you guys tried the aem one?
http://aempower.com/ViewProduct.aspx?ProductID=598
Old Jul 15, 2008 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR@SPEC &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by turbotypeR@SPEC at 6:20 PM 7/15/2008</TD></TR></TABLE>
I told u that you a baller!!!
Old Jul 15, 2008 | 03:31 PM
25 Year Member
Default Re: Fast SFWDers whats your intake air temps (B18c1turboedEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEK &raquo;</TD></TR><TR><TD CLASS="quote">Have you guys tried the aem one?
http://aempower.com/ViewProduct.aspx?ProductID=598</TD></TR></TABLE>
i think that one only goes to ground. the plx is 0-5v.
BTW- i'm not the baller. you are thinking about the man in the mirror.LOL
Old Jul 15, 2008 | 03:34 PM
Yea i tought it was also, but i just DL the instructions and its based of the GM one!
Old Jul 15, 2008 | 03:40 PM
25 Year Member
i think it is gm
Old Jul 15, 2008 | 03:45 PM
lwct100's Avatar
Temp sensor in stock location on the victor x manifold. Im going to be changing my intercooler set up next week, Ill be doubling my surface area. Ill Repost the results after Im done. It will be neat to see if there any big gains in power.
