90 Hatch dx DPFI popping back fire
Old Jul 14, 2008 | 04:17 PM
chuck403's Avatar
Default 90 Hatch dx DPFI popping back fire HELP!!!
I have a 90dx hatch with the Dual point fuel injection set up. I started the car and it perfectly about a mile to the store i shut it off and when i tryed to turn it back on 5 minutes later it would not start or catch to turn on. it keeps cranking and once in 3 cranks it will start but POP POP like some one trew a m80 in the exhaust pipe. i am not sure whats wrong but i have tested for the following
1)Spark i have from taling each out and cranking the engine.
2) i have plenty of fuel probly too much because i can smell it in the carburator.
3) the fuel pump turns on every time the ignition is turned on and it primes fine.
4) i have not done a compression test yet but i dont see how after one mile of driving i can blow something. pleas help me out or the cleanest cream puff ef hatch that i have and love will be junked!!!
Modified by chuck403 at 6:15 PM 7/14/2008
Old Jul 14, 2008 | 04:30 PM
KHMERXB0I213's Avatar
Default Re: 90 Hatch dx DPFI popping back fire HELP!!! (chuck403)
ur o2 sensor or spark wires or cat...
Old Jul 14, 2008 | 04:34 PM
97grnrs's Avatar
Default Re: 90 Hatch dx DPFI popping back fire HELP!!! (KHMERXB0I213)
ive seen timing belts jump a few teeth and cause that.
Old Jul 14, 2008 | 05:23 PM
chuck403's Avatar
Oh i for got to ad that i checked the timing cam gear, #1 piston and the rotor on the distributor line up. i dont know if i got the spark plug wires right.i know that after all this started happening i regaped the plugs and put them in started the car and it lasted longer than the last times. i think my fireing order is wrong but please someone correct me if im wrong it goes
4321 and on the distributor:
2 3
1 4
Thanks for the replys
Old Jul 15, 2008 | 01:42 AM
chuck403's Avatar
Help BUMP
Old Jul 15, 2008 | 02:01 AM
taylor1's Avatar
Default Re: (chuck403)
what motor you running D15B2
here look at this link
http://autorepair.about.com/li...f.htm
there is a pic of the order for you
Modified by taylor1 at 3:12 AM 7/15/2008
Old Jul 15, 2008 | 02:09 AM
ef yu's Avatar
Default Re: (taylor1)
it seems to me u have the firing order wrong on the distributor goodluck
Old Jul 15, 2008 | 04:23 AM
EF_9's Avatar
Default Re: (ef yu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">it seems to me u have the firing order wrong on the distributor goodluck
x2
check to see if the screw came out of the rotor if so get a new cap and rotor (did the same thing again when i changed)
i suggest getting a new dizzy if not its a good to time to do a mpfi swap!!!
Old Jul 15, 2008 | 03:22 PM
chuck403's Avatar
Thanks to all for the Good sugestions. here goes the update:
I came home from work looked at the car and?HA hA no i did not blow it up yet i was thinking the same thing on the fireing order too so i switched the wires around and started the car and first crank it came right on. well when it came on it slowly started to rev up higher and higher so i turned it off. my thinking has me going towards the timing belt jumped a tooth? but i know i have compression,spark, and fuel so the timing and fire order has to be the lsat two things i have to miss with. i am happy i started it but i have more work to do. i will be back with an update and again thanks for the info.if yall have any other idea or sugestion post it up.
Old Jul 15, 2008 | 03:24 PM
chuck403's Avatar
Oh and yes its a D15b2
Old Jul 15, 2008 | 10:22 PM
taylor1's Avatar
the idle screw on the DPFI sucks @ss and it will tighen it self up so back it out a little and see if that fixs it it did it on my STD and that way it went from 500 to 1500 rpm
Old Jul 15, 2008 | 10:27 PM
ef yu's Avatar
sticky throttle cable? tap the gas pedal a bit and see if it comes down.
Old Jul 16, 2008 | 04:40 PM
chuck403's Avatar
Well i missed with it again and the firing order was wrong. i got that fixed now when i first start it the idle jumps up and down fast intell it gets warm and it starts to slow down. when i try to give it gas the idle goes up and dont come back down intell i give it full gas then it goes back to up and down. i did switch carbs with one that was supposed to be good but i think something might be wrong with it. the car is not throwing any check eng lights or codes. could the tps be going bad or the Iac? i am close to getting this car on the road so any suggestions at all would be greatly appreciated. thanks for all the help.
jmpassey
Aug 5, 2018 11:45 AM
FoxRacing254
10
Jan 6, 2011 12:57 PM
NedeN
Feb 21, 2009 07:25 PM
htwanky2a
17
Feb 15, 2005 06:46 PM
