b16ef wont start getting fuel and spark
Old Jul 14, 2008 | 02:10 PM
jweeks's Avatar
Default b16ef wont start getting fuel and spark
I dont know what the deal is with my hatch im not throwing any codes im getting a spark though it looks weak its orange and I can smell the fuel and hear the pump kick on. the ecu will blink at me when I turn the key too. before it was running fine and then it wouldnt even turn over, I put a bigger ground on the valve cover and then it started turning over. anyone have an idea whats going on
guy_from_nerk's Avatar
Default Re: b16ef wont start getting fuel and spark (jweeks)
Did you just put this motor in the car? Check grounds and timing
Old Jul 14, 2008 | 02:11 PM
gursh d's Avatar
have you checked compression? timing?
Have you checked your grounds? Main relay?
Old Jul 14, 2008 | 02:18 PM
jweeks's Avatar
Default Re: b16ef wont start getting fuel and spark (gursh d)
grounds are good, motors been in for about 10k miles havnt checked the compression or timing I looked at the belt to see if it was broke it was nice and tight what could make it jump. and it sounds like it has compression but I have no tester, tried ecu and main relay
Old Jul 14, 2008 | 04:35 PM
97grnrs's Avatar
check the theremostat ground. its important
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
Phantastic
May 28, 2010 03:15 PM
EF927
Jan 25, 2010 03:54 PM
rodvang
Dec 25, 2007 08:37 AM
ericlee303
Apr 28, 2004 03:31 PM
