Crx Question
I bought a crx off this guy. He drop in a motor from a 88 sedan. the motor ran when it was in the sedan. Now that he put it in there it wont even start up. Could you guys give any answer to this or any thoughts about what could be wrong with it?
And thanks for the help and im a noob to this form thanks again.
yeah sorry about that. I check all the small things to it. the engine is a d15y8. When i turn the key it sounded like a buzzing noise. The guys said that it could be a wiring problem with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewy1985 »</TD></TR><TR><TD CLASS="quote">yeah sorry about that. I check all the small things to it. the engine is a d15y8. When i turn the key it sounded like a buzzing noise. The guys said that it could be a wiring problem with it.</TD></TR></TABLE> So it doesn't even cranky?
How is it wired?
Is your battery ok?
Starter?
How is it wired?
Is your battery ok?
Starter?
There is no such thing as a d15y8, did you mean d16y8? If so, that's from a 98 sedan, not an 88. Also, you would need to use all the old stuff from the old motor. If your car isn't MPFI then you'll have to convert over before that engine will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewy1985 »</TD></TR><TR><TD CLASS="quote">thanks again for the help got it running and it was a d16 not d15</TD></TR></TABLE>
just curious, what was the problem?
