Analyze my time slip plz
Old Jul 19, 2002 | 11:58 PM
Qwikrex's Avatar
Default Analyze my time slip plz
Ok here was my best run out of 3 runs tonight. This was my first time at the track . The temp. outside was hot and very humid.
R/T .825
60' 2.661
330 7.024
1/8 10.451
MPH 72.79
1000' 13.353
1/4 15.812
MPH 91.24
What is my car capable of running, and what can I do to improve my times? On this run I launched at around 5000 rpm dumping the clutch on stock Michelin tires. My front tire pressure was 28 psi and rear was 35psi. All mods are in my sig in addition to removed back seat/spare.
Thanks
[Modified by [VTEC]TL, 9:00 AM 7/20/2002]
Old Jul 19, 2002 | 11:59 PM
nwdave's Avatar
Default Re: Analyze my time slip plz ([VTEC]TL)
Get some better tires.
Stockers =
Old Jul 20, 2002 | 12:02 AM
Civic1.6VTEC's Avatar
was this at Moroso?? i think i saw a car just like your sign.
Old Jul 20, 2002 | 12:03 AM
Qwikrex's Avatar
Default Re: Analyze my time slip plz (Civic1.6VTEC)
Yeah this was at Moroso just a couple hours ago
Old Jul 20, 2002 | 12:17 AM
what kind of clutch do you have?? also, the tires need to go.
and practice on the reaction time. did you miss any gears??
my boy with a blue 92 sohc si ran a 15.82.
Old Jul 20, 2002 | 12:42 AM
eg6RR's Avatar
work on the r/t and get a set of slicks on some 13in rims
ahhaahhaah but it will better ur time
and try some gasoline booster
Old Jul 20, 2002 | 05:12 AM
EKB18BPR3's Avatar
Default Re: Analyze my time slip plz (CTRKID)
15.8...what engine?
EKB18BPR3's Avatar
Default Re: Analyze my time slip plz (dniedacess)
never mind
Old Jul 20, 2002 | 05:43 AM
deez92's Avatar
r/t has nothing to do with your quarter mile time, you need to improve your 60' times, try launching at 3,000 and go up from there
Old Jul 20, 2002 | 06:00 AM
memphiss13's Avatar
Default Re: Analyze my time slip plz (deez92)
look at his 60' thats where the problem is, 2.6 is not good at all. try to get closer to a 2.2
Old Jul 20, 2002 | 10:36 AM
Qwikrex's Avatar
Default Re: Analyze my time slip plz (rookie2nr)
Yeah this was my first time at the track. My 60 ft. was a garbage 2.661. I also noticed that my trap speed was higher than a stock Si at 91.24. Another Si at the track was running 16.1-16.2. And an EK hatch with a B18c1 swap ran a 14.7. So everyone was running garbage times on this hot muggy, humid night. I talked to an Si owner on clubsi and he ran a 14.977 @ 91.34 mph with a 2.206 60 ft(not at the same track). His trap speed was almost equal to mine so with better tires and a good 60 ft. I'm hoping for low low 15's. And if I'm lucky, and it's pretty cold and dry out, maybe I can hope for a high high 14.
[Modified by [VTEC]TL, 7:44 PM 7/20/2002]
Old Jul 20, 2002 | 11:08 AM
JV's Avatar
JV
Who?
The almighty crappy 60'... It'll get you everytime...
Old Jul 20, 2002 | 11:36 AM
krazy's Avatar
the 60 ft suck like a ****...work on those and u will do good times. i say low 15s. the reason the traps are so high is because of no traction. the more the tires spin the higher the traps. when u run ur best time, the traps will get lower unless u have done something to make more power. once there was too much water on the track because some idiot did a burnout in the box with radials , so he dragged water on to the starting line, anyway i launched and got crazy wheel spin because of the water. i ended up getting a 16.7 at 97 mph. usually ill be running mid to high 14s wiht traps at only 93-94. get those 60ft times down and u will see. also lower the front tire pressure to about 22-23 psi if u have to run on stockers. dont worry this is still safe.
Old Jul 20, 2002 | 12:47 PM
i know it doesn't, but if you were racing for real, he would have loss.
Old Jul 20, 2002 | 01:05 PM
Vanilla4215's Avatar
you said that you dumped the clutch at 5000 rpm. Don't DUMP the CLUTCH! Feather it out.
Old Jul 20, 2002 | 01:15 PM
gsrvx's Avatar
New User
Default Re: Analyze my time slip plz (Vanilla4215)
feather it!!! I feather my clutch and was able to pull off 2.2 times. This is a hatch w/gsr motor on 13inch vx wheels and bald stock tires. Practice and you'll get better.
-Rod
Old Jul 20, 2002 | 10:29 PM
Qwikrex's Avatar
Default Re: Analyze my time slip plz (RK)
So with a good launch I should be good for low 15's? Is that about right for my mods(listed in sig) plus no spare/jack/backseat/powersteering? Also, for every second you take off of your 60 ft. how much does it take off of your 1/4 time?
Old Jul 20, 2002 | 10:45 PM
deez92's Avatar
a sec. will take off alot. but every tenth of a sec. should drop 2 tenths off your time
Old Jul 20, 2002 | 10:52 PM
tFUnK's Avatar
you could be capable of running high 14's with your mods... and some better tires. why did you put stock tires on rota slipstreams?
Old Jul 20, 2002 | 11:26 PM
Qwikrex's Avatar
Default Re: Analyze my time slip plz (tFUnK)
I was broke at the time As a matter of fact, I still am
[Modified by [VTEC]TL, 8:26 AM 7/21/2002]
Old Jul 21, 2002 | 12:44 AM
turbo_ef9's Avatar
-Rod
feather it? dont feather it.. i pulled last night a 13.63@100 on a civic gsr.. i grabbed a 2.151 60 ft with street tires dumping the clutch at 4k.. i dunno bout you guys but this is how i do it.. and to get the times that you want you need to improve that 60 ft to a 2.2.. you'll be happier with your run..
Old Jul 21, 2002 | 02:09 AM
gsrvx's Avatar
New User
Default Re: Analyze my time slip plz (b16_ef)
What kinda street tires did u do that on? Pretty good...I've dumped the clutch on mine plenty of times...always gotten 2.4 60fts.
Old Jul 21, 2002 | 08:48 AM
-Rod
That is the first time I have ever heard of this happening. I'm not calling you a liar or anything, just commenting. on the launch!
Old Jul 21, 2002 | 08:41 PM
turbo_ef9's Avatar
hehe.. forgot to metion.. this is also with an itr lsd tranny... i coulda done better but i ran it for my cousin.. hes twice the size of me and still a begginer.. hes getting good.. he gets better 60's than me.. but i'm just a lil faster.. to him..
Old Jul 21, 2002 | 08:48 PM
DX Hybridizer's Avatar
Your 60ft says it all. As with all honda's I've seen this really makes or breaks your time tenth or two hear off and your down a second from what you could run. My time is in my sig. I am usually getting a 2.2 or 2.3 with mine. I use my stock 13 with some crap firestone tires. I run my psi at 26.5 at the front. I check them after each run as they do tend to heat back up.
Granted your in a 00 to my 95. But you should be at least a 1/2 second faster, the heat probably played a good effect. What do you launch at? I launch at 4300. I slip for a split second and usual drop into base vtec of 4K. Pratice your launch rpm. Watch were your rpm's are at when you gain traction etc. This is how I perfected my times.
Ask others that ran how they felt the track was slippery, etc. Helps you figure how your doing. As always the more you practice the better you get.
GOOD LUCK.
Terrible One
33
Jul 15, 2005 01:34 PM
Mark
Oct 2, 2003 08:17 PM
flip1199
Jul 18, 2002 11:48 AM
01PYTypeR#1140
May 24, 2002 01:30 PM
