Prelude wont turn over from time to time
Old Jul 14, 2008 | 10:35 AM
preludexballer's Avatar
Default Prelude wont turn over from time to time
hey eveyone, just got a 92 prelude 2.2. sometimes when i start it up it wont turn over, i hear it cranking but it just wont start the engine. this happens sometimes when its pretty warm too. i would stop real quick and come bak and turn it back on but it just wont turn over, i have to give it a couple tries, and it finally does.
then it would turn over and i would hear the exhaust rumble and it wouldnt hold the idle and die. So when it does turn over i give it gas and then its good.
this only happens time to time and has happens randomly
What could be the reason for this? it needs a speed sensor replaced if that has anything to do with it(speedometer wont tell the speed.)
The last owner did say he left it sitting for awhile.
Old Jul 14, 2008 | 12:47 PM
stunn'd's Avatar
I would check out the distributor, take off the cap and clean the contact points inside as well as the rotor. Use a wire brush or a small file, just enough to get any build up off.
If that doesn't help, you might want to do some tests on your coil and igniter unit inside the distributor the next time it doesn't start.
Old Jul 15, 2008 | 06:25 AM
Jagan'92's Avatar
Default Re: Prelude wont turn over from time to time (preludexballer)
If it's heat related it could be the main relay (fuel relay). You can resolder the relay contacts or get a new one. Do an archive search here for main relay and get the pics.
Old Jul 15, 2008 | 12:13 PM
snobordboy's Avatar
Moderator
Yeah sounds like a main relay to me, resolder should do the trick, took me like 20 minutes. I leave the case bolted in under the dash, and just pop the insides out.
Ultemate
Jun 13, 2019 08:03 PM
TigerLy
Mar 18, 2012 07:02 PM
aznboydat2
Jun 16, 2008 11:37 PM
noobiludekanoobi
Aug 29, 2006 01:39 PM
vadrad
Feb 11, 2005 01:12 AM
