<-----SAFC PROBLEM! HELP PLZ!----->
Old Jul 19, 2002 | 11:33 PM
-Racer X-
Guest
Posts: n/a
Default <-----SAFC PROBLEM! HELP PLZ!----->
ok, i tryed installing my SAFC on my b18a ecu (93 integra), i printed all the documentation from apexi-usa.com/documentation.asp and followed everything correctly and re checked it like 5 times...and the result was when i put it in the "on" position, the buttons would light up and the screen wouldent do anything, but then if you hit a button and held it down the program would start until you let go of that button...what do you think it could be? a bad connector? cause we used some easy splice connter things to piggyback all the wiring, and yes someone who has installed one before did all the work and i had checked the unit the night before i bought it offa this guy i know (so i know it all works fine), i just wanna know if there is any special webpages out there or anything special i have to do to get it to work on my 93 integra ECU... o btw the diagram i used was ha-2 which followed my pins correctly.
Thanks
Old Jul 20, 2002 | 06:29 PM
GTM's Avatar
GTM
Default Re: <-----SAFC PROBLEM! HELP PLZ!-----> (-Racer X-)
Common problem brother! You've been swinging the S-AFC around by it's harness wire and you pulled the harness out of its internal socket. You probably noticed that the buttons are on the same sire the wire enters the AFC case...
Remedy: CAREFULLY unscrew the case of the AFC and make sure all the internal connections are sound.
Good luck.
tylerd92
14
May 11, 2015 03:02 PM
ljoe
Jan 27, 2004 10:35 AM
-Racer X-
Jul 20, 2002 11:23 PM
