<-----SAFC PROBLEM! HELP PLZ!----->
Old Jul 19, 2002 | 11:32 PM
-Racer X-
Guest
Posts: n/a
Default <-----SAFC PROBLEM! HELP PLZ!----->
ok, i tryed installing my SAFC on my b18a ecu (93 integra), i printed all the documentation from apexi-usa.com/documentation.asp and followed everything correctly and re checked it like 5 times...and the result was when i put it in the "on" position, the buttons would light up and the screen wouldent do anything, but then if you hit a button and held it down the program would start until you let go of that button...what do you think it could be? a bad connector? cause we used some easy splice connter things to piggyback all the wiring, and yes someone who has installed one before did all the work and i had checked the unit the night before i bought it offa this guy i know (so i know it all works fine), i just wanna know if there is any special webpages out there or anything special i have to do to get it to work on my 93 integra ECU... o btw the diagram i used was ha-2 which followed my pins correctly.
Thanks
Old Jul 20, 2002 | 06:43 AM
Audi A4's Avatar
Default Re: <-----SAFC PROBLEM! HELP PLZ!-----> (-Racer X-)
take it off and reinstall it. theres 2 grounds right
Old Jul 20, 2002 | 09:53 AM
GSG2's Avatar
just solder the wires, it's more reliable. yeah ur connection might be bad.
Old Jul 20, 2002 | 10:44 AM
blacksheep's Avatar
Default Re: <-----SAFC PROBLEM! HELP PLZ!-----> (jobau)
Yeah.. it's more than likely a bad connection somewhere. I didn't solder my wires, I just used some good connectors. I don't like the ones that come with it.. those things
Old Jul 20, 2002 | 05:29 PM
-Racer X-
Guest
Posts: n/a
i got it used so i bought scotch locks from kragens...im about to just sodler it in
Old Jul 20, 2002 | 05:45 PM
-Racer X-
Guest
Posts: n/a
ya, and my freinds totally deny that its their install that was the problem, they say the AFC is broken, but how cant hat be when i was palying with it from the guy i bought it from the night before??
Old Jul 20, 2002 | 07:32 PM
zojirushi's Avatar
theres a way to test the afc out... take yours out, and connect it to a friends car who already has an afc setup. That way u can see if the afc works.
Old Jul 20, 2002 | 11:23 PM
-Racer X-
Guest
Posts: n/a
Default Re: <-----SAFC PROBLEM! HELP PLZ!-----> (zojirushi)
hmmmm....ya, ill try that...
2kTeg
Mar 25, 2006 09:53 PM
ljoe
Jan 27, 2004 10:35 AM
NewIntegraKid
Sep 26, 2002 10:00 PM
-Racer X-
Jul 20, 2002 06:29 PM
