JDM 4-1 lower heat shield rattle, what to do?
Old Jul 19, 2002 | 11:15 PM
onyx00's Avatar
Default JDM 4-1 lower heat shield rattle, what to do?
I installed the JDM header bracket and now the lower heat shield rattles a lot. Ideas on what to do? The bolt closest to the cat. holding th shield it broken due to the head comming off a bolt, so that could be one cause I guess.
Can I just remove the lower heat shield? Isn't there some aftermarket or thirds party companies that make different kinds of lower heat shields for headers?
Old Jul 19, 2002 | 11:17 PM
disordeR's Avatar
Default Re: JDM 4-1 lower heat shield rattle, what to do? (onyx00)
EH, just use the upper heat shield.
Old Jul 20, 2002 | 04:31 AM
ITR764's Avatar
get rid of the lower sheild.
Old Jul 20, 2002 | 04:44 AM
jdmhatch's Avatar
Why dont you guys think he should use the lower shield. Then i always hear about people complaining that they scraped or dented their header and ****. I personally would keep it if i were you. Just try to do something about getting that bolt out.
Old Jul 20, 2002 | 07:21 AM
Dr Pooface's Avatar
Default Re: JDM 4-1 lower heat shield rattle, what to do? (jdmhatch)
earplugs
Old Jul 20, 2002 | 08:33 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Fastline Performance makes a lower skid plate for the JDM 4-1 header; check out thier website @ http://www.fastlineperformance.com
later
matt
Old Jul 20, 2002 | 09:45 AM
onyx00's Avatar
Default Re: JDM 4-1 lower heat shield rattle, what to do? (b16a5gracer)
I think I am going to take the header off and get some new bolts welded to it so I can use better bolts. That should easily solve the problem.
Old Jul 20, 2002 | 10:01 AM
GokuSSJ4's Avatar
Default Re: JDM 4-1 lower heat shield rattle, what to do? (ITR764)
[Modified by Spoon1, 7:01 PM 7/20/2002]
onyx00
Apr 3, 2002 04:16 PM
comptechgsr
Dec 26, 2001 05:17 PM
Rguy
Jun 16, 2001 09:56 PM
