What engine oil are you using?
There is the question, what oil are you using for what kind of set up? Just trying to get a general idea. Thanks guys
94 Hatch D15B (SOHC Vtec):
I use Royal Purple 10W30. I don't tend to use conditioners, but I have used Restore before. I got it @ Advance Auto Parts. It worked well for my Accord with 170XXX + (F22 motor), never burned any oil. I have always used K + N oil filters.
I highly recommend the Royal Purlple Synchromax manual transmission fluid, especially for hard driving applications. They also make ATF, and coolant additives, which I also use and recommend.
JDM B18C R, 98+ Spec, I/E, Mobil 1 10w30. Fram oil filter, because they have the hand grip thing on the end and I dont have a filter wrench
I only use Mobil 1 because Autozone never carries Royal Purple in 5w30 or 10w30, and I like to use my $20 discount for oil changes.
Both on my D16Z6 (I/H/E) and my D16Y8 (I/H) I run/ran Mobil 1 fully synthetic 10w30 (green!) with an autozone filter.
Never had a problem.
EDIT:
I don't use additives to make it last longer, or seafoam, or any of that jazz - I also don't use the "5000 mile no change" line of Moibl 1 or whatever - I use the regular and change it every 3000.
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Both on my D16Z6 (I/H/E) and my D16Y8 (I/H) I run/ran Mobil 1 fully synthetic 10w30 (green!) with an autozone filter.
EDIT:
I don't use additives to make it last longer, or seafoam, or any of that jazz - I also don't use the "5000 mile no change" line of Moibl 1 or whatever - I use the regular and change it every 3000.</TD></TR></TABLE>
I don't use the additive so I can make the mileage last longer, I still go 3 months, 3000 miles. I use it for that extra protection so I don't burn a ring or anything like that. It will actually clean out years of engine sludge after the first change... I just made sure I changed it a week or so after just using regular non-synthetic oil and sure enough, the darkness poured out. I'd recommend it to anyone
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sugarfree »</TD></TR><TR><TD CLASS="quote">castrol edge 5w30
(used to be called castrol formula r)
dont kno if american got that or not....
Dam is that any good? don't think we have this in the US...
Bone stock z6 using mobil clean 5000 5w-30 with a wix filter. Changed ever 3000 miles. The oil was good enough to make help my z24 cavalier to 375,000 miles, when i sold it, i figured its pretty good stuff!
