90 DA rear disc brakes into 98 civic ??
Old Jul 13, 2008 | 03:20 PM
B-serious's Avatar
Default 90 DA rear disc brakes into 98 civic ??
Would rear disc brakes from a 90 integra work on a 98 civic DX?
Old Jul 13, 2008 | 03:51 PM
BlueIntegraBoy's Avatar
Default Re: 90 DA rear disc brakes into 98 civic ?? (B-serious)
yes
Old Jul 13, 2008 | 05:05 PM
Cuda's Avatar
Default Re: 90 DA rear disc brakes into 98 civic ?? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
yup and just for reference... all teg/civic rear disk brake will bolt up...
Old Jul 14, 2008 | 06:46 AM
B-serious's Avatar
Default Re: 90 DA rear disc brakes into 98 civic ?? (Cuda)
so i can use everything from the 90 teg to do a disc brake conversion onto the civic?
how do i run the brake lines?
Modified by B-serious at 8:06 AM 7/14/2008
Old Jul 15, 2008 | 07:29 AM
B-serious's Avatar
Old Jul 15, 2008 | 08:13 AM
gsxr1k05's Avatar
look up the rear disc brake conversion in the faq. but i can tell you that the rear trailing arm bushings are more expensive for the 90-93 teg arms than the 94-00. incedently, you can remove all the hardware from the 90 teg arm and bolt it all to the civic arm (i had to do this with one cause the bolt was frozen and snapped). this will also allow you to use the stock civic arms and replace the bushings with the cheaper 28 dollar ones rather than the 75 dollar 90 teg arm bushings. just remember to get an alignment when your done. if you need more info pm me and i will explain further.
Mazzi-91-civic
Oct 14, 2006 10:27 AM
1CiViC1
Feb 15, 2004 06:55 PM
hondahans
Jan 27, 2004 03:33 PM
Bob_Digi
Aug 22, 2003 08:03 AM
lsvtecrx
22
Nov 8, 2002 02:02 AM
