Car problems... need help pretty quick.
Old Jul 19, 2002 | 09:30 PM
ivanED9's Avatar
Default Car problems... need help pretty quick.
Here is the symptom: I would turn the key 2 over, lights would come on, then when i would turn the key fully over there would be a clickign sound and ****** kill the battery (the same feeling like when you leave your lights on, then you come back to turn on your car and you get NOTHING!). Then, I'd get no power from the battery at all. Cant even turn on the lights anymore afterwards... weird huh?! Is this a loose ground? Starter? What?
This is really pissing me off cuzz my pile o **** has been causing me problems for like a whole month now, and its getting really annoying not having a car.
Old Jul 19, 2002 | 09:43 PM
Mugen Dom's Avatar
Default Re: Car problems... need help pretty quick. (ivanED9)
ivan did u do anywiring for teh zc???? maybe a shorted wire mine did it last week and it was a shorting wire for mpfi
Old Jul 20, 2002 | 03:09 AM
91ED7Si's Avatar
yer battery cables proli loose cuz thats what mine does.
Old Jul 20, 2002 | 03:21 AM
CRX1770's Avatar
1. check if your wires are grounded properly
2. make sure your battery terminals are nice and tight
3. try to find out if your alternator is going bad
4. see if your dome light is staying onwhen you leave the car
Mine constanly has btteryproblems and I basically run it for 15 minutes every morning before i go drive to my work, 5 minutes away.
trianglegreg
May 15, 2008 12:23 PM
squirrly
May 11, 2008 07:40 PM
jpnucrx
Jun 19, 2006 05:04 PM
hb_racer
Jun 16, 2004 08:05 AM
91sifreak
Sep 18, 2001 05:17 AM
