Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
How much oil do you burn?
Old Jul 13, 2008 | 07:37 AM
25RFG2's Avatar
Default How much oil do you burn?
07 civic Si 26,xxx miles and she burns close to 4 quarts every 3000 miles. car use to have intake race header and exhaust but is back to stock. I dont drive it hard just alot of highway miles for work.... any help would be great.
Old Jul 13, 2008 | 09:06 AM
SIVIC 3's Avatar
it burns all its oil before its time for the next oil change?
burns or loses? do you have a leak?
sounds like a pretty big problem to me.
Old Jul 13, 2008 | 09:31 AM
pgpbubble's Avatar
Default Re: How much oil do you burn? (25RFG2)
go to your dealer n tell them your vehicle is consuming oil. They should print you out a consuming oil report, and they'll have you come back every few days to check on it. Your vehicle is still covered under manufacturers warrenty.
Old Jul 13, 2008 | 09:32 AM
25RFG2's Avatar
Default Re: (SIVIC 3)
it has no leaks just burns it. Would the dealer warranty it for me if they had seen it with the mods?
Old Jul 13, 2008 | 10:34 AM
pgpbubble's Avatar
Default Re: (25RFG2)
It all depends on your dealer honestly, We warrenty trans jobs that have race headers, intakes. whatever basically.
Old Jul 13, 2008 | 11:07 AM
i-VTEC_DOHC's Avatar
pgpbubble: he said his car is back to stock.
now thats a big problem. my car burned around a quart or so when i was breaking it in.
but it doesnt burn oil anymore and i have 11k miles.
but u still have warranty so i would go to the dealer. this is somethin u shouldnt put of.
Old Jul 13, 2008 | 11:28 AM
SIVIC 3's Avatar
Default Re: (pgpbubble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble &raquo;</TD></TR><TR><TD CLASS="quote">It all depends on your dealer honestly, We warrenty trans jobs that have race headers, intakes. whatever basically.</TD></TR></TABLE>
trans. job has what to do with an oil problem?
and since when do express tech's do warranty transmission work? just wondering.
Old Jul 13, 2008 | 02:18 PM
jewjew bean's Avatar
If you came to the dealer with mods previously, they usually don't make a record of it unless it's on you service receipt
Old Jul 14, 2008 | 08:51 AM
GoLowDrew's Avatar
Old Member
25 Year Member
A car this young driking that much oil is bad news. Do you see white smoke in your tail pipe? Maybe not. Sometimes engine will drinks it without any evidence. It could be pistion rings going bad. There is not much you can do short of a new engine.
1. Take it to a dealership and document the problem. They will top off and mark where the starting point is.
2. Drive it like normal.
3. They may ask you to come back after 800 miles to measure lost. If you loose 2 qrt or more than half on the dipstick, they should get you a new engine.
4. Compression test. If failed = new engine.
^^^^^ These are "not" Honda rules. I experience similar issue with oil lost and it was their plan. So I'm sure Honda have similar plans. If not, make the dealer play by some kind of rule so they can see there is a problem.
Old Jul 14, 2008 | 09:06 AM
CerealKiller's Avatar
pistons rings?
Old Jul 14, 2008 | 10:49 AM
25RFG2's Avatar
Default Re: How much oil do you burn? (GoLowDrew)
Thanks for all the help. We did notice under heavy acceleration the car looks like a turbo diesel dumping alot of black smoke for the exhaust. I made an appointment with Honda for tomorrow so will keep you guys posted. once again thanks for the help.
Old Jul 16, 2008 | 07:51 AM
25RFG2's Avatar
Well after having my car at the dealership they said I have to bring it back on monday and leave it for five hours.
Old Jul 16, 2008 | 12:54 PM
Bulli Kid's Avatar
Well at least they will look deeper into the problem, sounds like a ring was installed incorrectly.
Good luck and not trying to make you feel worse but
My R18 doesn't burn any oil.
What was your method of break in?
Old Jul 17, 2008 | 07:38 AM
Zeusone's Avatar
do you drive around with no oil?
Old Jul 17, 2008 | 09:25 AM
dirtySOHC's's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoLowDrew &raquo;</TD></TR><TR><TD CLASS="quote"> Do you see white smoke in your tail pipe?
white smoke NORMALLY indicates headgasket problems. white smoke shows that water is somehow getting into the combustion chamber and burning off.
and if the dipstick shows more than half gone then that means it's HALF a quart low....not 2 quarts. that measurement on the dipstick indicates 1 full quart.
Old Jul 17, 2008 | 12:28 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: How much oil do you burn? (dirtySOHC's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC’s &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe that's true on a Honda engine. My oil lost problem was not a Honda. If it was, I would be very because I expect more from Honda.
Old Jul 17, 2008 | 12:43 PM
Maybe that's true on a Honda engine. My oil lost problem was not a Honda. If it was, I would be very because I expect more from Honda.</TD></TR></TABLE>
then word of advice....next time make sure you provide the correct information. a lot of young guys or guys period in this forum are very impressionable and would listen to every word you say.
your previous statement about the dipstick could have had someone filling up there car with a quart and a half more oil than it really needed.
Old Jul 17, 2008 | 02:05 PM
GoLowDrew's Avatar
Old Member
25 Year Member
You are right. I would hope people would read carefully that I was not talking about Honda. And that Honda would have similar type of guidelines or policy that dealers should follow. So the OP should expect some kind of plan offered to him.
Old Jul 28, 2008 | 07:37 PM
kartman5's Avatar
2000 miles and down a qt. Dealership topped it off and said not to worry!
Old Jul 29, 2008 | 06:24 AM
Default Re: How much oil do you burn? (kartman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kartman5 &raquo;</TD></TR><TR><TD CLASS="quote">2000 miles and down a qt. Dealership topped it off and said not to worry!</TD></TR></TABLE>
unfortunately, that's typical for any manufacture. 2k per quart is still considered acceptable.
Old Jul 29, 2008 | 06:45 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: How much oil do you burn? (jewjew bean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewjew bean &raquo;</TD></TR><TR><TD CLASS="quote">
unfortunately, that's typical for any manufacture. 2k per quart is still considered acceptable. </TD></TR></TABLE>
This is why I traded-in my 06 SE-R Spec V. Fully mod- Project done. I loved that car. It lost oil within the "acceptable" range according to Nissan. Even thou there was a recall and Nissan replaced many QR25DE engines, mine was "acceptable."
I should not need to add a qrt myself between oil changes, for a then brand new car. I had hope it was just a break in phase kind of thing. But it was not.
IMO, the engine was set to fail sometime later on. Perhaps after the engine warranty runs out? I cut my losses now instead of later for a peace of mind - even thou I really lost big in terms of $$$$.
Old Jul 29, 2008 | 03:16 PM
You have to make note of your driving conditions. If it's burning a quart per 2k miles with little load and minimal rpm, it's a problem that needs to be fixed. ON the other hand, if you're driving the car HARD, you have to expect some oil consumption.
Old Aug 10, 2008 | 06:49 PM
Mr. DB2's Avatar
My 08 FA5 has already consumed 1qt of oil @ 900 miles.Thats sad.My old 92 GS-R would only burn 1qt between oil changes and it had 270k miles when I sold it.
Old Aug 11, 2008 | 03:02 AM
Default Re: (Mr. DB2)
did you buy your 92 GSR brand new back in 92? Im sure the oil consumption rate is almost comparable to your 08 civic.
Old Aug 11, 2008 | 03:42 AM
GriFFIthS's Avatar
my 2001 civic dx "uses" about 1-2 quarts of oil in between changes (5000 km's) i've had it at the dealer, its not burning the oil, no blue smoke, theres no leak, and they told me not to worry about it thats its normal and some cars just use the oil.
my brother in law has been driving and working on honda's for the last 15 years and he to said its normal, he if its not leaking, and you cant notice it burning off then not to worry about it, he's driving a 2005 accord v6 and he said he uses roughly the same amount in between changes.
