Loud noise coming from shifter??
lately ive ben hearing grinding/rattling niose when i get on it hard...the noise will start at about 5k rpm and get louder/more violent up to redline...then it will go waway once i shift then it will come back once i near the redlne again..
it sounds like its coming from the shifter...but if i firmly hold the shifter it only helps a lil bit. also it started doing it when i put the front shifter bushing in..but i didnt put the back one in cuz i got it for free.
also it doesnt do it during normal driving..just pushing it..anyone have a similar problem??
it might be hitting exhaust
Regards
I think the shifterbushings are worn-out. imho.
I am experiencing similair probs with my EE9... When rpm is around 4-5k I hear a ratling sound coming from the shifter (Loudest in 4th gear) ... when I hold my shifter its softens the noise... when I acellerate it stops...
Try to hold your shifter when you hear the noise or press your clutch... when it dies away... replace your shifter bushing...
Definately check to see if it is hitting the exaust, mine does that too since i just installed a Skunk 2 short shifter. it hits in reverse and 5th and 3rd.
