1991 Accord A/C question.
Old Jul 12, 2008 | 11:28 PM
JONESER's Avatar
Default Is it just me????
I have a 1991 Accord Wagon and the air blows cold if you put your hand to the vent, but its hard to feel from the seat.
The A/C has plenty of freon, but it seems like the blower just doesnt have much force. Is anyone else's A/C do this? My buddies 96 Civic is the same way.
My **** gets cold , but it takes FOREVER! I also have an Expedition & a Ranger and the A/C blows HARD AS HELL through the vents in both of those trucks.
Someone please help me with some kind of fix that can make my A/C blow better.
Old Jul 13, 2008 | 06:23 AM
-RedneckDave-'s Avatar
Working
Default Re: Is it just me???? (JONESER)
Replace the foam connections on your ducts behind your dash so that the air does not leak out.
Old Jul 13, 2008 | 06:04 PM
hmbtjc29's Avatar
Default Re: Is it just me???? (-RedneckDave-)
Also, see that your blower motor is not full of junk (leaves). Are there distinct steps when you turn up the blower speed? Are you sure that it's not staying at a low speed? If it is, it could be a bad regulator.
Old Jul 13, 2008 | 11:51 PM
JONESER's Avatar
Default Re: Is it just me???? (hmbtjc29)
The steps aren't very distinct... The first couple settings feels like it's not even on. High(all the way up) feels like its on one of the first couple steps in either of my trucks.
Old Jul 14, 2008 | 04:37 AM
hmbtjc29's Avatar
If you cannot hear the blower speed increasing as you're turning up the dial, or if it only blows on one setting and not the others, you might be looking at a regulator.
Can you hear anything rushling around or something that sounds like a card in bicycle spokes under the glove box when it's on (as in leaves)?
Old Jul 14, 2008 | 05:53 PM
JONESER's Avatar
Okay... It does increase every step on the fan control. I listened pretty close while the air was on and I didn't hear any (rustling)goin' on in there. I did just figure out that my condensor fan is not working. I traced it down to be the motor. I'm not thinking that would have anything to do with it cuz the A/C does blow cold.
Old Jul 16, 2008 | 07:24 PM
JONESER's Avatar
Anyone????? Could this be doing this because the fan isn't working?
Old Jul 16, 2008 | 09:04 PM
stereo69's Avatar
sounds like the blower motor is bad or theres crap blocking air flow best to pull the motor and check for blockage it could be leaves or somthing..
Old Jul 31, 2008 | 07:28 PM
joepoe's Avatar
Tim, did you ever get this figured out? My '93 Accord has same problem.
Atalbot20
Mar 31, 2018 09:32 AM
rotascircuit
Jan 5, 2010 10:58 PM
pellegrino
Nov 9, 2008 07:38 PM
synNikal
May 3, 2007 09:41 AM
HondaChiGirl
Nov 5, 2004 07:04 AM
