Broken piece off of h22 transmission
Old Jul 12, 2008 | 06:46 PM
Cannon Man's Avatar
Default Broken piece off of h22 transmission
I recently did and auto to manual swap, and after filling the trans I put the fill bolt back on. When I put it on and tightened it the threaded bottom half snapped off
(where the red silicone I tried to seal it with is)
What should I look into to repair it? Im willing to do whatever it takes short of replacing the tranny case or the tranny itself. All suggestions are welcomed, Thanks
Heres a pic of the piece that came off (covered with metal epoxy I previously tried to seal it back on with)
Old Jul 12, 2008 | 07:32 PM
TurboLSVtecTeg's Avatar
Default Re: Broken piece off of h22 transmission (Cannon Man)
Well first off thats not the fill bolt. The fill bolt is a 17mm too the left of the passenger side axle in your picture(you cant see it). I would personally replace the case. But I guess depending on he damage too the case you can see if it will hold up.
Old Jul 13, 2008 | 01:33 AM
Cannon Man's Avatar
Default Re: Broken piece off of h22 transmission (TurboLSVtecTeg)
*Noted. Im trying to avoid taking out the whole tranny to repair it if I can do so, but I wanna make sure whatever I do is done right. Do you happen to know if the case for the f series would also be a direct swap?
Old Jul 13, 2008 | 06:42 AM
k24em2's Avatar
After you've covered that little part in that epoxy and silicone crap its gonna be very difficult to weld in back on unless you spend a great deal of time cleaning it all off.
Old Jul 13, 2008 | 09:25 AM
Cannon Man's Avatar
Default Re: Broken piece off of h22 transmission (k24em2)
I dont mind cleaning it since Ive got dremels and different sand paper around the house, as long as it is still possible to weld.
Old Jul 13, 2008 | 05:15 PM
k24em2's Avatar
Anything is possible for the right money. You'd be better off buying a new case.
Old Jul 13, 2008 | 08:35 PM
KNS Autosport's Avatar
I have to agree with evryone else, Replace the case
Old Jul 13, 2008 | 09:33 PM
Cannon Man's Avatar
Default Re: (KNS Autosport)
Looks like I got my solution. Thanks for the help
Old Jul 14, 2008 | 12:03 AM
pcguy760's Avatar
Default Re: (Cannon Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cannon Man &raquo;</TD></TR><TR><TD CLASS="quote">Looks like I got my solution. Thanks for the help</TD></TR></TABLE>
So what was your solution? Just curious
Old Jul 14, 2008 | 10:28 AM
c1_sleeper's Avatar
Default Re: (pcguy760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">
So what was your solution? Just curious </TD></TR></TABLE>
i think he's just gna get a new case
Old Jul 14, 2008 | 10:59 AM
Timmah!!'s Avatar
Replace the case... OR... JB Wled the CRAP out of it. I think it would hold. I did that to the ear of a starter motor once and its been in my car for 3 years
Old Jul 14, 2008 | 12:43 PM
c1_sleeper's Avatar
Default Re: (Timmah!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmah!! &raquo;</TD></TR><TR><TD CLASS="quote">Replace the case... OR... JB Wled the CRAP out of it. I think it would hold. I did that to the ear of a starter motor once and its been in my car for 3 years </TD></TR></TABLE>
we tried jb weld. it didnt work so we used a metal epoxy that was stronger than the jb weld. but it didnt hold up either
Old Jul 14, 2008 | 06:51 PM
Finest's Avatar
Default Re: (c1_sleeper)
Did you clean up the area around it before applying the JB weld? It needs to be shiny new metal underneath to hold.
Old Jul 14, 2008 | 06:56 PM
c1_sleeper's Avatar
Default Re: (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">Did you clean up the area around it before applying the JB weld? It needs to be shiny new metal underneath to hold. </TD></TR></TABLE>
yea we did that.. we sanded it down pretty good than applied it
Old Jul 14, 2008 | 08:17 PM
Cannon Man's Avatar
Sup cuz. I went back and hit it with the epoxy again w/o the small broken piece. Apparently it didnt hold the first time cause that bolt never sat flush. Hopefully it'll hold the fluid til I get a new case. Down for a tranny removal at pick a part w/o a lift or jack?
Old Jul 14, 2008 | 08:24 PM
c1_sleeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cannon Man &raquo;</TD></TR><TR><TD CLASS="quote">Sup cuz. I went back and hit it with the epoxy again w/o the small broken piece. Apparently it didnt hold the first time cause that bolt never sat flush. Hopefully it'll hold the fluid til I get a new case. Down for a tranny removal at pick a part w/o a lift or jack?</TD></TR></TABLE>
Hell Yea. i wouldnt do it any other way
Old Jul 14, 2008 | 08:27 PM
Cannon Man's Avatar
Fo sho. Hopefully the f an h cases are interchangangle. Next up, wheel bearings
Old Jul 15, 2008 | 09:34 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i'll sell you a spare h-series complete casing...i'll sell on the cheap cheap. pm me if you are interested.
Old Jul 15, 2008 | 10:01 AM
Eddiebx's Avatar
remember if u replace the case, u have to check all the preloads on teh bearings, such as the differential bearings and waht not.
Old Jul 15, 2008 | 03:37 PM
LordAphotic's Avatar
this isnt a hard fix... u just need to take off the transmission.. drain it. clean it. and get it welded...
either have them weld on the same piece or a new piece.....
then u just use a large tap to make sure u have perfect threads again. then done.
Old Jul 16, 2008 | 09:57 AM
dartonh22's Avatar
Default Re: (LordAphotic)
i have the same problem with my m2b4 excpet i ripped out the bolt holes that hold it to the rear t bracket, still havent gotten around to fixing it, so please post up your fix when you do fix it.
Old Jul 22, 2008 | 01:26 PM
extralargenog's Avatar
Default Re: (dartonh22)
F case will work as well...
I have a H case id part out for just the half (the pass side of the case) you need if interested PM me... Say 75 bux + you pay ship... PM me if interested.
BrownProdigy
Feb 8, 2015 10:56 AM
Accord01324
Apr 19, 2007 05:09 PM
mikegeezy
Mar 21, 2006 07:06 PM
..::Ken::..
Feb 11, 2004 04:23 PM
KwikSilverACC
May 24, 2003 11:02 PM
