Question on Intake manifold?
Old Jul 12, 2008 | 02:34 PM
killingtwobirds's Avatar
Default Question on Intake manifold?
I recently ordered a 94 h22a and when I got the motor in under the intake manifold theirs a black box that was cracked. it has a couple of vacuum lines on it... what is that part called and do I really need it? thanks
Modified by killingtwobirds at 7:47 PM 7/12/2008
Old Jul 12, 2008 | 04:32 PM
Hawkze_2.3's Avatar
Default Re: Question on Intake manifold? (killingtwobirds)
It is a vacuum box for the IAB system.
Old Jul 12, 2008 | 06:50 PM
Default Re: Question on Intake manifold? (Hawkze_2.3)
Whats the IAB system do? might you know where a website that would sell one? thanks
Old Jul 12, 2008 | 07:04 PM
Hawkze_2.3's Avatar
Intake Air Bypass, there are 8 runners in the intake manifold and 4 of them have butterfly valves. The IAB system keeps the butterflies closed at low rpms for better low end power, and then opens them at higher rpms for better top end. 2-stage intake manifold would be another name for it....
You can go to hondaautomotiveparts.com or slhondaparts.com for OEM stuff.
Old Jul 12, 2008 | 07:48 PM
BlackCatt's Avatar
You could also try your local honda wrecker if you have one nearby.
Old Jul 12, 2008 | 08:18 PM
drbenne's Avatar
this is the part no. 36361-PT2-014
it's like $27 plus shipping from slhonda. Like someone suggested you might want to check the local salvage yard for one, if not, they're really not that expensive.
thunderboy
Jul 19, 2008 06:10 PM
0260MOTORSPORTS
Oct 12, 2006 08:31 AM
tea
Oct 24, 2003 05:01 AM
