SEARCHED: Removal of interior door panel in a 94 Civic Hatch
I want to replace my stock speakers and need to remove the door panel, but i have no idea how to without possibly breaking watever is holding it on. Please post link if available with step by step instructions or if you have done this before then tell me how. Thanks!
no offense but if you need instructions on removing the door panel i think you shouldn't be removing it. and im sure the EG speakers are like the EKs you don't need to remove the door panel to take out your door speakers..... AND there is like 2 screws one near the door handle that you pull to open the door(inside) and one in the little thing you put your fingers into to close the door and obviously remove your window handle there is a little C clip i believe its a bitch to get out but when its out you can just pull the handle off and then its all like clips just pull....
