how would i make hx wheels fit on my eg hatch with si front knuckles?
Old Jul 12, 2008 | 12:48 PM
hondaon18's's Avatar
Default how would i make hx wheels fit on my eg hatch with si front knuckles?
i need to make my hx wheels fit on my eg i have all the si front brake conversion and rear brake also. how could i make it fit with out rubbing on the caliper?
Old Jul 12, 2008 | 12:54 PM
immajackuup's Avatar
Default Re: how would i make hx wheels fit on my eg hatch with si front knuckles? (hondaon18's)
u noob u ever heard of search?
Old Jul 12, 2008 | 01:18 PM
ek_si hatch's Avatar
Default Re: how would i make hx wheels fit on my eg hatch with si front knuckles? (immajackuup)
i hate a$$ holes like this *****, if u cant answer his question u shouldn't post anything at all!!! ps. i wouldnt know
Old Jul 12, 2008 | 01:29 PM
HellerDopeEK4's Avatar
get some 5mm wheel spacers at pepboys or autozone... thats what my hommie did he has 95 ex coupe with hx rims.. it rubbed the caliper but when he put the spacers on it was koo...
Old Jul 12, 2008 | 02:27 PM
mini-e's Avatar
i have front 99-00 si knuckles and calipers on a ek hatch with hx wheels. i ground a bit off the caliper bracket to get it to fit and then painted the recently exposed caliper bracket metal with caliper paint. there is a thread in here somewhere with pics- its was not much material at all in my case.
Old Jul 12, 2008 | 03:24 PM
Default Re: how would i make hx wheels fit on my eg hatch with si front knuckles? (ek_si hatch)
u need to shut up because most of the people on here tell me to search.
Old Jul 12, 2008 | 04:46 PM
mini-e's Avatar
i need?
Old Jul 12, 2008 | 09:20 PM
Default Re: how would i make hx wheels fit on my eg hatch with si front knuckles? (mini-e)
no ek si hatch homo ***
Old Jul 12, 2008 | 09:25 PM
turbojdmhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">no ek si hatch homo ***</TD></TR></TABLE>
Old Jul 13, 2008 | 05:47 AM
GodsSon's Avatar
lol...
anyways theres two different ways you can make them fit.
1. get 5mm spacers which can be found at your local auto parts store
-or-
2. shave off the outer caliper bracket that faces the center of the rim. after this is done it will eventually rust so just paint it with rust prevention black paint
good luck on your install
Old Jul 13, 2008 | 07:08 AM
Default Re: (GodsSon)
okay i didn't know i was going to start a riot on this question? but thier called 5m spacers. ok also will i need them for the rear also since i converted it to disks or just the front?
Old Jul 13, 2008 | 09:05 AM
mini-e's Avatar
Default Re: (hondaon18's)
just the front. on the rear hx wheels fit by a mile over disks.
the spacers cost money, the grinding is free.
if you go the spacer route research as to whether or not if you need longer studs. maybe someone will answer here.
Old Jul 13, 2008 | 09:46 AM
Default Re: (mini-e)
what so will i need long studs so do i have to get hub pressed off to change the studs or can i just knock them out with a hammer?
Old Jul 13, 2008 | 11:58 AM
93grayeg's Avatar
5mm spacers
Old Jul 13, 2008 | 01:20 PM
mini-e's Avatar
Default Re: (93grayeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93grayeg &raquo;</TD></TR><TR><TD CLASS="quote">5mm spacers </TD></TR></TABLE>
can he use the studs as is?
Old Jul 13, 2008 | 01:38 PM
Lmgrcivic's Avatar
you can use the wheel studs you have now. 5mm is only about a 2 threads at most not a big deal.
Old Jul 13, 2008 | 02:45 PM
(A): just cuz other people tell ur lame a$$ to search doesn't mean u need to be queer like them!!!.........and (B): i know theres no si hatch and thats why im converting mine into one...idiot. and (C) ur just plane queer!!!!!!
Old Jul 13, 2008 | 07:33 PM
don't make me do u in the pooper
kmeng
18
Jan 7, 2009 08:33 PM
akces
Apr 13, 2008 01:59 AM
Eg4Kory
Feb 5, 2008 10:57 PM
Yak BallZ
18
Feb 10, 2005 05:13 PM
IheartSpoon
11
Jul 26, 2002 02:14 PM
