help with wiring problem
Old Jul 12, 2008 | 12:30 AM
kenlrw39's Avatar
Default help with wiring problem
ok i bought an 89 hatch with a ls swap i guess there was a problem with the wiring so the previous owner removed it and started to intall a crx si wiring harness but now that i'm finishing it up i have a few extra plugs that dont match up with anythingand my high beam light is on even thoough the lights aren't on can anybody help me throught this mess?
Old Jul 12, 2008 | 08:26 AM
black0hatch's Avatar
Default Re: help with wiring problem (kenlrw39)
if you need help you have to atleast say what plugs.
Old Jul 12, 2008 | 11:31 AM
kenlrw39's Avatar
i don't know what plugs they are thers 3 by the ucu and i already pluged in the air stuff theres a blue one with 2 yellow wires behing the cluster another coming out of the harness that plugs into the air and heat control and i for some reason i have no power to my dash lights and my fuel pump.
Old Jul 12, 2008 | 02:08 PM
kenlrw39's Avatar
does anybody have any pics of there fuse box under the dash and of under the passenger side dash and are there relays that plug into the back of the fuse box? i'm so lost.
Old Jul 13, 2008 | 10:33 AM
kenlrw39's Avatar
can anybody tell me why i might not have power at fuses 2, 4, 5, 6, 7, 8, 9, and 10 under the dash and what they go to and why when i turn the i have no power at the end of the wire that goes to the fuel pump?
Old Jul 13, 2008 | 11:38 AM
Blown90hatcH's Avatar
For starters, did he even install the correct year harness. They are not all compatible thru the EF years.
Old Jul 13, 2008 | 12:40 PM
kenlrw39's Avatar
i don't know i think it came from an 89 crx si and are there any fuse or circuts that go on the backside of the fuse box or is that all plugs and wires? and does the cluster wires have to be repined to work with the si wiring cause when i turn on my lights the oil light comes on and when i do high beams the check engine light comes on.
Old Jul 13, 2008 | 05:49 PM
wesleywhite989's Avatar
Default Re: (kenlrw39)
i got the same problem with my cluster lol i have a ls vtec and none of my gauges work not temp fuel speedo or tach... and when i turn my lights on the check engine light comes on so does the door being opend and it says i need to close the hatch lol ***** all messed up
Old Jul 13, 2008 | 10:49 PM
kenlrw39's Avatar
well i kinda solved my problem i started changing the pins around cause i guess the crx si harness doesn't match up with the cluster i have and this cluster doesn't have a tach either but if i can get it figured out by tomorrow i'll post up my fix.
Old Jul 13, 2008 | 10:52 PM
kenlrw39's Avatar
Default Re: (wesleywhite989)
http://crxcommunity.com/viewtopic.php?p=65118
here is the link i'm using to figure out wire colors.
Old Jul 14, 2008 | 02:45 PM
kenlrw39's Avatar
can anybody tell me were the green connecter on the crx si wire harness on the drivers side goes to?
Old Jul 14, 2008 | 03:06 PM
DCRB's Avatar
nvm.
Old Jul 14, 2008 | 11:01 PM
kenlrw39's Avatar
Default Re: (DCRB)
what's nvm? i'm new to this honda wiring
tek_civic
Apr 6, 2006 12:13 AM
Aaron.
Mar 28, 2003 03:38 PM
