Signficance of shifting speed?
I ran my all motor LS before with an LS tranny, stock clutch, stock flywheel, and stock cat and ran a 14.55 @ 97mph. Very respectable, and I was able to run mid 14's all day with similar trap speeds.
Since then, I installed an J1 (b16a) tranny, exedy clutch, ITR flywheel, and am now running a testpipe. I also stripped the rear of the car to the bone. I went to the track and could break into 14's. The car feels much faster in every gear, but the best time I could muster up was a 15.03 @ 90mph ...
Obviously I tried playing around with fuel pressure, cam timing, ignition timing, reset ECU.. The thing was is that I'm running a different short shifter than I had before, and my first run I couldn't even get the car into 2nd (first time shifting @ 8k on the new tranny/clutch). So 2nd run I jammed it into 2nd (I couldn't do it nearly as fast as I could with my old setup) and I slowly started improving my times.
The conditions were very similar, and DEFINATELY not big enough of a difference to set me BACK another 7mph @ 1/2 second. I'm figuring the much slower shifting is to blame as opposed to small little tunings here & there. I'm convinced by changing the shifter back to stock I can start shifting like I used to and bring down those times BIG TIME... My friend figures its pretty likely every slower shift (lets say 3 tenths slower each shift) can easily make a HUGE difference. Just wondering what you guys think... TIA
Nobody? Ok here's coles:
Car went 14.55 @ 97 mph very similiar conditions, I changed stuff which should make it go a lot faster BUT I couldn't shift as fast as before, in fact I had to fight to get it in 2nd. The best time I could get was a 15.03 @ 90mph... QUESTION: can slow shifting hurt times this badly?
also, what was this ls all motor setup that was netting you 14.5? must have been f*cking awesome without a clutch...
