Colored OEM lug nuts?
Old Jul 11, 2008 | 04:20 PM
hybrid90's Avatar
Default Colored OEM lug nuts?
Is there a vendor that sells colored lug nuts with a ball seat head like OEM? I want some PIZAZZ in my stock wheels!
Old Jul 12, 2008 | 12:55 PM
hotrod99's Avatar
Default Re: Colored OEM lug nuts? (hybrid90)
nope,you could try painting or powdercoating the oem ones,but i doubt it will last very long
Old Jul 12, 2008 | 01:40 PM
nsxtasy's Avatar
H-T Order of Merit
Does black work for you? If so, you can get black lug nuts from your Acura dealer that will work on most Honda and Acura wheels. You can even get black wheel locks to match. Look in the FAQ topic stickied at the top of this forum for the part number(s).
Old Jul 12, 2008 | 05:52 PM
hybrid90's Avatar
Default Re: Colored OEM lug nuts? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Does black work for you? If so, you can get black lug nuts from your Acura dealer that will work on most Honda and Acura wheels. You can even get black wheel locks to match. Look in the FAQ topic stickied at the top of this forum for the part number(s).
Hey thanks for the info.. I'm actually looking for red ones though. I have found these on ebay but not sure if they can be used with stock wheels.. I've emailed the seller but no response so far... they look good though.
http://cgi.ebay.com/ebaymotors...87550
Old Jul 12, 2008 | 06:31 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid90 &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks for the info.. I'm actually looking for red ones though. I have found these on ebay but not sure if they can be used with stock wheels.. I've emailed the seller but no response so far... they look good though.</TD></TR></TABLE>
I am not personally familiar with those. However, don't just ask the seller if they can be used with stock wheels; he will undoubtedly say yes, or give you some BS about the shape of the seating area not being important (NOT TRUE). If you need to, you can give him a link to the pictures in the FAQ topic, where it shows the lug nuts with the ball shape and the tapered shape on the seating area.
Old Jul 12, 2008 | 08:27 PM
hybrid90's Avatar
Hey good point ya got there.. I'll do just that.. send him some pics of exactly what I needed. Thanks!
Old Jul 14, 2008 | 01:07 PM
tekniq's Avatar
acura dealers don't carry black lug nuts...i called them and they said that they never had either...
Old Jul 14, 2008 | 03:01 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Colored OEM lug nuts? (tekniq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">acura dealers don't carry black lug nuts...i called them and they said that they never had either...</TD></TR></TABLE>
Most don't carry them in stock. However, if you just give them the part number, they can order them for you. Call them back and give them the part number and ask them if they can get them, and they will say yes.
Old Jul 14, 2008 | 03:15 PM
tekniq's Avatar
nsxtasy....do you know the part number by chance? also...i just wanted to know if acorn buldge seat lug nuts are the same as ball seat lug nuts. i read a thread around here saying that acorn and ball seat lugs are the same thing..just need some reassurance. if so and if the dealership denies me for some odd reason, i was looking to get these: http://www.brandsport.com/grla-91137bc.html
Old Jul 14, 2008 | 04:41 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">nsxtasy....do you know the part number by chance?</TD></TR></TABLE>
Look above ^^^^. The third post in this topic says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">you can get black lug nuts from your Acura dealer that will work on most Honda and Acura wheels. You can even get black wheel locks to match. <FONT SIZE="4">Look in the FAQ topic stickied at the top of this forum for the part number(s).</FONT></TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to know if acorn buldge seat lug nuts are the same as ball seat lug nuts. i read a thread around here saying that acorn and ball seat lugs are the same thing..just need some reassurance.</TD></TR></TABLE>
Not necessarily. "Acorn", when applied to lug nuts, sometimes means different things. Some people and companies use it to refer to the ball-shaped seating area which Honda/Acura wheels require, which is what you want. However, others (including the McGard and Gorilla websites) use it to refer to the shape of the other end of the lug nut (i.e. NOT the end that comes into contact with the wheels). So you have to be careful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">if so and if the dealership denies me for some odd reason, i was looking to get these: http://www.brandsport.com/grla-91137bc.html</TD></TR></TABLE>
Those have a tapered seating area, and should NOT be used with Honda/Acura wheels. You can view all the Gorilla lug nuts on all seven pages of their website here. The ONLY ones that should be used with Honda/Acura wheels are their item number 38138 (closed end) and 38038 (open end), shown on page 7, which have the ball-shaped seating area. NOT the ones shown in your link.
Old Jul 14, 2008 | 06:03 PM
tekniq's Avatar
hey thanks a lot dude, you're the man do you know if the 97-98 NSX lugs will fit my 00 si OEM wheels? i found some for 2.50 a piece for 97-98 NSX lugs.
Modified by tekniq at 1:27 AM 7/15/2008
Old Jul 15, 2008 | 01:23 PM
tekniq's Avatar
bump bump
Old Jul 15, 2008 | 02:50 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (tekniq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekniq &raquo;</TD></TR><TR><TD CLASS="quote">hey thanks a lot dude, you're the man do you know if the 97-98 NSX lugs will fit my 00 si OEM wheels? i found some for 2.50 a piece for 97-98 NSX lugs.</TD></TR></TABLE>
The '97-05 NSX lug nuts will fit your wheels. However, those years, the lug nuts had a chrome finish (part number 90304-SA5-013). The black finish lug nuts (part number 90304-SA7-811) were only used for the '91-96 NSX. So if you want black finish lug nuts, you'll need to get them from the '91-96 NSX, or order the right part number from your Acura dealer.
If you want chrome finish lug nuts, you may as well get them from your local Autozone or other auto parts store. If you do that, make sure they have the ball-shaped seat, of course. Last time I bought some from Autozone a couple of years ago, I think they were $1.09 each.
Old Jul 15, 2008 | 11:34 PM
tekniq's Avatar
ahh i see..thanks dude
Old Oct 30, 2008 | 09:41 PM
brandobot89's Avatar
I've been reading about for colored lug nuts, i've browsed a few forums and found this..
"your wrong. my work lugs and my mugen heptagons seat the same as stock lugs. "
More people talk about it in this thread also.. https://honda-tech.com/zerothread?id=2356491
Is this true? I noticed a lot of people with jdm itr rims ride on these work rs lug nuts.
Here's a pic of the lug nuts..
http://www.procivic.com/pages-...htmlz
I need help finding red lug nuts that'll fit OEM wheels, I don't awnna paint my own.
how about these?
http://www.gorilla-auto.com/sm...ge_13
http://forums.clubrsx.com/showthread.php?t=602179
these also look somewhat ball seated..are acorn and ball seated the same for Honda? They're going to be on dc5 itr rims..
How about adapters to change conical to ball seat?
http://forums.vwvortex.com/zerothread?id=4066324
i've never heard of the above...
Modified by brandobot89 at 11:06 PM 10/30/2008
Old Oct 31, 2008 | 06:03 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (brandobot89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">"your wrong. my work lugs and my mugen heptagons seat the same as stock lugs. "
More people talk about it in this thread also.. https://honda-tech.com/zerothread?id=2356491</TD></TR></TABLE>
At least one of the people posting there is just plain WRONG.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">Is this true?</TD></TR></TABLE>
NO!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">I noticed a lot of people with jdm itr rims ride on these work rs lug nuts.</TD></TR></TABLE>
I've seen a lot of people doing things that are unsafe. I've seen people drive around on cars with one or two lug nuts missing. I've also seen people snap studs and lose wheels that way.
The problem is that lug nuts with the wrong (i.e. mismatched) seating area can still be screwed onto the studs and tightened with a lug wrench, so that people think they're safe - right up until the point where they start working themselves loose. DON'T DO IT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">Here's a pic of the lug nuts..
http://www.procivic.com/pages-...htmlz </TD></TR></TABLE>
That pic very clearly shows that the lug nuts have a tapered seating area, not the ball-shaped seating area that Honda/Acura wheels have and need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">how about these?
these also look somewhat ball seated..are acorn and ball seated the same for Honda? They're going to be on dc5 itr rims..</TD></TR></TABLE>
Both of those very clearly have a TAPERED seating area, and should not be used on those rims.
Note that the word "acorn", as used on the Gorilla website, does NOT refer to the shape of the seating area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">How about adapters to change conical to ball seat?
i've never heard of the above...</TD></TR></TABLE>
Neither have I. As noted in that topic, if you use them, make sure you have enough threads when turning your lug nuts.
Of course, the safe, sensible, and easy route is to just get lug nuts with the right shape seating area to match your wheels.
Old Oct 31, 2008 | 12:16 PM
Default Re: (nsxtasy)
thanks! just wanted to clarify, i've been googling for hours and i've been finding mixed answers..
Old Oct 31, 2008 | 01:03 PM
TunerN00b's Avatar
This pic help explain just how bad using the incorrect lugs is.
Notice how some of the lugs are missing the colored coating in only a tiny circle around the seat? That little circle, is the entire seating surface when using mismatched lugs.
You want the entire seating surface of the lug to be in contact with the wheel. Anything else, is asking for trouble.
Old Nov 2, 2008 | 11:30 AM
EP3H's Avatar
Default Re: (TunerN00b)
Spoon offers an oem lug nut replacement. They are gunmetal i bellieve but at $100 you might as well get the black acuras. Plus they are not red.
Anyway my point was Spoon offers oem replacements.
Old Nov 2, 2008 | 11:52 AM
TecHnOCal's Avatar
Default Re: (EP3H)
^^is box of lugs from someone on 8thcivic? i know i saw that pic the other day...maybe it was on h-t. lol
Old Nov 2, 2008 | 01:29 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (TecHnOCal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TecHnOCal &raquo;</TD></TR><TR><TD CLASS="quote">^^is box of lugs from someone on 8thcivic? i know i saw that pic the other day...maybe it was on h-t. lol</TD></TR></TABLE>
It's from the h-t topic in the first link in brandobot's post above.
Old Nov 5, 2008 | 09:12 PM
Noodle wAgon's Avatar
https://honda-tech.com/zerothread/2348067
some swagga
Old Nov 12, 2008 | 01:54 PM
YoungMoneySi's Avatar
Default Re: (Noodle wAgon)
i have some open ended lug nuts from autozone. are those bad or will cause damage to my ride or are they ok to use?
Old Nov 12, 2008 | 02:30 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (YoungMoneySi)
There's nothing bad about using them from the fact that they're open ended. The key question is the shape of the seating area, which is the area on the wheel and the area on the lug nut that come into contact with each other. You need to make sure the shape of the seating area on the lug nuts is the same as the shape of the seating area on the wheels. Most Honda/Acura wheels have a ball (radius) shaped seating area, and so do stock lug nuts. Most aftermarket wheels have a conical (tapered) seating area, and need lug nuts that have that too.
Old Nov 12, 2008 | 05:17 PM
these are what i have on my stock Si wheels. are these ok or will they do damage to the wheels? i havent seen any damage on my wheels yet from using these. will they do damage anywhere else or hurt any other part of the car?
http://cgi.ebay.com/ebaymotors...ories
