FS Trade 92 Honda Prelude F22b DOHC Turbo Intercooled Eastern Pa 3500 obo
Hi there im selling my 1992 prelude, i bought this car about two years ago as a daily driver then decided to build this into hi performance street car during the past year. I have two 92 preludes and both must go and im letting this one go first with the intentions of getting a four door car.This car has less than 200 miles on new motor and clutch, and less than 50 miles on the turbo set up .The motor itself as less than 50k It has a full turbo kit and just needs to be tuned its running a chrome base map right now.Kelly blue values my car at 3000 in excellent condition but i'd say its in good condition and is valued at 2500. The mods alone cost me +- 3700 not including labor. I am asking 3500 O.B.O. . I'll also throw in a flip up jesen cd/mp3/dvd player with 7" touch screen if i get more than 3000. Clean title. Im located in bethlehem pa If you have any question feel free to ask
TURBO
Full t3/t4 T04E hybrid turbo kit
Cast iron turbo manifold (crome welded turbo manifold included also) $200
T3/T4 T04E .63 trim hybrid turbo $150
Custom mig welded 3 inch downpipe $100
Brand new cat back exhaust system $140
Hollow cat pipe(original included) $37
38MM waste gate, spring set at 3.8 (I have a boost controller included to be installed) $80
Dumptube for wast gate $40
Ecu has been programed to hold 7 psi of boost
Turbo xs blow off valve $30
27x5.5x 2.5 intercooler $100
Boost gauge installed (extra one included along with oil pressure,airfuel ratio also) $30
Total=$900
ENGINE
JDM F22B DOHC (Basically the same as an H23A) $600 plus $120 shipping
Brand new oem Exedy clutch, pressure plate and flywheel (less than 200 miles on it) $220
Walboro 255lph fuel pump installed $99
Rebuilt DSM 450cc injectors $165
P06 ECU converted to P28 / P72 / P30 specifications. $158
1.ZIF(zero insertion force) socket
2. An on/off Jumper switch used to change from the stock OEM program to the chip program
3. A datalogging header used for tuning.
4. Also included is a SST 27SF512 re-writeable chip.
5. Parts needed for VTEC use.
16" slim racing fan (Not installed) $40
Less than 50,000 on engine
Horsepower: 160 HP @ 6000 RPM
Torque: 148 LBS-FT @ 5000 RPM
Fuel Control: OBD-1
Compression: 9.3:1
Bore: 85.0mm
Stroke: 95.0mm
Red Line: 7000rpm
Total=$1402
THE CAR
New inspection in May
Ohma orange paint $140
Brand new rotors all around and brake pads $200
Adjustable coilovers installed $60
Newer axles $150
New radiator $100
Blitz fiberglass front bumper $220
Wing west polyurathane side skirts $50
Wing west rear lip $50
Altezza rear lights $60
Black one piece front head lights $150
17 ultra light rims with low profile tires, excellent tread left on them $400
Total=$1420
TURBO
Total=$900
ENGINE
Fuel Control: OBD-1
Compression: 9.3:1
Bore: 85.0mm
Stroke: 95.0mm
Red Line: 7000rpm
Total=$1402
THE CAR
Newer axles $150
New radiator $100
Total=$1420
contact me at suzi_racer85@hotmail.com if you're interested in selling these wheels..or trading..i have 2 sets i need to get rid of
XES
Jul 21, 2008 09:41 PM
preluderob92
Jul 13, 2008 04:44 PM
D-meet07
Sep 25, 2006 07:09 PM
