Smog Check questions?
I have a 89 CRX Si with a JDM B16A engine, Mugen PR3 chipped ECU and need to get my car smogged. Is there anything I can do to make a legal smog besides replacing the engine? Any comments are appreciated. Thanks.
You will never pass with your setup... Heres a list of what you need... Its also in the FAQ...
USDM P30-A00 ECU
ECU jumper harness *Depending on REF, Some don't like them.*
OBD-1 Dizzy *B16 or GSR*
OBD-1 Throttle body. * I passed with a GSR, But the nipple for the Charchol canister bent to the left instead of bending straight up. Needs MAP sensor*
CARB Legal Skunk2 Intake Manifold
OBD-1 Thermostat housing w/ temp sensor *Again depending on REF*
Electric VSS *Again depending on REF*
DATA LINK CONNECTOR *Again depending on REF*
Alex
USDM P30-A00 ECU
Alex
Soichiro Jr.
Feb 2, 2004 05:59 PM
91civicEX
19
Jan 12, 2004 06:28 AM
