nitrous??
Old Jul 10, 2008 | 10:15 PM
juanintec's Avatar
Default nitrous??
how much nitrous can i put on a stock d16z6 without blowing it??
thanks
Old Jul 10, 2008 | 10:30 PM
pimpwagon's Avatar
Default Re: nitrous?? (juanintec)
dou you have a stand alone fuel management, and how well can you tune it? if the answer was neither, id say you could prob push a dry 50 or wet 75 if you didnt use it too much.
Old Jul 10, 2008 | 10:42 PM
juanintec's Avatar
Default Re: nitrous?? (pimpwagon)
whats the diffrence of wet and dry??
Old Jul 10, 2008 | 11:48 PM
bryantracing's Avatar
wet also pumps in extra fuel and is a little more effective. dry just sprays the nitrous and doesnt have as hard of a punch. If i was you i would take pimp wagons advice and start with a 50 or 75. then depending on how the car reacts you can go from there.
Old Jul 11, 2008 | 12:06 AM
EFstyle's Avatar
Default Re: nitrous?? (bryantracing)
... I wouldn't go any higher then a 50 on a stock D-Series... then again i wouldnt put nitrous on a stock D-Series... well whatever you decide to do... the best of luck to you... Cheers!
P.S. your D will be in my prayers
Old Jul 11, 2008 | 07:43 AM
B34M3R's Avatar
No offence, but if you don't know the difference between a wet and a dry shot, I think you need to do some more research on nitrous kits in general. If you really want the biggest shot, you need to find the right plugs, a way to retard the ignition timing, a window switch, and a dyno sesson to make sure your AF is right on the juice.
Otherwise, you're asking your motor to kill itself. I wouldn't go past a 50wet on a D-series without what I mentioned... oh, and quick reference... don't for the love of god use a dry kit... they are weaker and more damaging.
Old Jul 11, 2008 | 08:25 AM
sinepome's Avatar
Default Re:
IMO i don't think nitrous is the way to go. you should invest you money into internals, and then if you still want it go with the bottle. but thats just MO
Old Jul 11, 2008 | 11:27 PM
juanintec's Avatar
Default Re: (B34M3R)
well i want to build a motor for nitrous.
but just have nitrous form once an a while.
do i have to sleeve it and what not to run it properly. what kind of pistons should i use for it??
later on i want to run 100 or 150 shot
Old Jul 13, 2008 | 02:42 AM
juanintec's Avatar
Default Re: (juanintec)
can i use high compression pistons with nitrous
you know low compression for turbo is it the same with nitrous or can i have high compression pistons??
Old Jul 13, 2008 | 06:43 AM
beana's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanintec &raquo;</TD></TR><TR><TD CLASS="quote">whats the diffrence of wet and dry??</TD></TR></TABLE>
a dry system causes loud noises that cost a lot of money to fix
seriously it just n2o gas thats going in , i don't recomend dry because your more prone to detonationif you don't get enough fuel
a wet system uses fuel and n2o which is better at keeping cylinder temps to a minimum ,and since your sending fuel into the cylinder your risk of detonation is minimal
---------beana
Old Jul 13, 2008 | 10:44 AM
coupej1's Avatar
run a wet system and no more then 75shot
Old Jul 13, 2008 | 11:08 AM
juanintec's Avatar
Default Re: (coupej1)
thats what im trying to go for like 50 or 75 shot
but what kind of piston should i use can i use high compression
Old Jul 13, 2008 | 01:50 PM
beana's Avatar
a nitrous system is very similar to forced induction ,can you run a nitrous system with high compression?......turbo,or supercharger yes you can but it all depends on compression ration, fuel octane rating, and intake temperature i can go on and on but i'm not going to
in short it's possible but i really don't recomend it
---Beana
Old Jul 13, 2008 | 01:54 PM
coupej1's Avatar
u can use stock pistions for a 75shot
Old Jul 13, 2008 | 05:47 PM
661rex89si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanintec &raquo;</TD></TR><TR><TD CLASS="quote">can i use high compression pistons with nitrous
you know low compression for turbo is it the same with nitrous or can i have high compression pistons??</TD></TR></TABLE>
nitrous like high compression but your just a noob at nitrous so start off slow and learn.
Old Jul 13, 2008 | 06:20 PM
black93octane's Avatar
Default Re: (661rex89si)
I have seen 125 shot on a single cam make about 5 passes then the engine dropped a valve. Just throw a shot of gas on it and have some fun. trial and error blow the heck out of it. ITs not like a d16 is hard to find. Ther is thousands of d series engines come on.
Old Jul 13, 2008 | 06:35 PM
juanintec's Avatar
somebody is trying to sell me a zex with 55 dry shot its the bottel and everything and a thing that connects to the fuel regulator to restrict the the fuel to rich in it up
is it a good deal??
Old Jul 13, 2008 | 09:16 PM
STREETWERKZ's Avatar
answer to the topic title: you're gonna blow your motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B34M3R &raquo;</TD></TR><TR><TD CLASS="quote">No offence, but if you don't know the difference between a wet and a dry shot, I think you need to do some more research on nitrous kits in general. If you really want the biggest shot, you need to find the right plugs, a way to retard the ignition timing, a window switch, and a dyno sesson to make sure your AF is right on the juice.
this guys sounds like he used to be bottle happy. I personally, LOVE the stuff.
one thing i would add is, current condition of the engine can effect it's total life.
Old Jul 13, 2008 | 11:49 PM
juanintec's Avatar
Default Re: nitrous?? (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanintec &raquo;</TD></TR><TR><TD CLASS="quote">somebody is trying to sell me a zex with 55 dry shot its the bottel and everything and a thing that connects to the fuel regulator to restrict the the fuel to rich in it up
is it a good deal??</TD></TR></TABLE>
so should i buy it??
Old Jul 14, 2008 | 12:37 AM
ef yu's Avatar
just buy the damn thing if you want it.
Old Jul 14, 2008 | 07:56 AM
thorclark's Avatar
one thing i would add is, current condition of the engine can effect it's total life. </TD></TR></TABLE>
Old Jul 14, 2008 | 12:18 PM
Iceycrx's Avatar
Despite what ANYONE says there is no safe number. Now what do most ppl do w/o typical problems, around 50-75 wet shot. There are to many variables to say how much is to much. Your motor condition plays a huge roll, the type of shot plays a role as well and what your doing for management does as well.
Old Jul 14, 2008 | 07:05 PM
Default Re: nitrous?? (Iceycrx)
I have a bone stock crx and I am goin to do a h2d swap in it. In the mean time while I collect the parts for my hseries I am going to throw a 75 shot and see how the stock d16a6 will handle it and if it does fine I will step up to a 100shot untill she blows. IT should be fun. Its not my daily driver. I have never blown an engine so this is my chance. haha
Old Jul 14, 2008 | 08:39 PM
juanintec's Avatar
Default Re: nitrous?? (black93octane)
haha thats what im talking about lol
but when i build my motor should i go high compression pistons for the nitrous??
Old Jul 14, 2008 | 09:29 PM
beana's Avatar
you guys just don't understand ....maybe we had to bust *** for what we have
yea i can be a dumb f*azz and say run it till you blow it but **** i know what i have and i know what i worked for show the guy some respect
don't say the d16/d15 are a dime a dozen because i got lucky with the i ended up with at least help a man out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
