O.Z. MSW Meshies: How do you take off the center caps?
Old Jul 10, 2008 | 08:32 PM
nubcake's Avatar
Default O.Z. MSW Meshies: How do you take off the center caps?
Update, posted some pictures of the hole/screw.
Hi, my friend recently cleaned out his garage and gave these rims to me. I am not sure what model it is, but it is similar to these rims, besides the rivets. My question is how do you take off the center caps? It seems there is a round hole to place something in there like a key, but I don't have it and I don't know how to take it out. I can take pictures of the hole tomorrow but here is an example of what the rims look like. Let me know if anyone can help me, thanks.
The last pictures is the same if not similar model of mine.
Modified by nubcake at 12:08 AM 7/16/2008
Old Jul 10, 2008 | 11:01 PM
r.wright's Avatar
Default Re: O.Z. MSW Meshies: How do you take off the center caps? (nubcake)
yeah some type of key man.. it's usually a round key w/like a triangular shaped pattern of 3 metal metal pegs that matches up to the holes then you just twist the screws off.
Old Jul 11, 2008 | 12:48 PM
nubcake's Avatar
Well I cannot get ahold of the key so is there any alt. to get it off?
Old Jul 11, 2008 | 12:55 PM
r.wright's Avatar
go to a hardware store and look around for tools. i never had that problem or maybe a local wheel shop can help
Old Jul 11, 2008 | 01:10 PM
nubcake's Avatar
Can you link me or post a tool that I should be looking for?
Old Jul 11, 2008 | 07:51 PM
nubcake's Avatar
Bump, I can't put these rims on without getting the center caps off.
Old Jul 12, 2008 | 01:55 PM
nsxtasy's Avatar
H-T Order of Merit
EDIT: This post is WRONG. See replies below.
<FONT COLOR="gray">I think they probably originally sold the wheels with a wrench that looked like this:
If the octagonal pattern in the middle is exactly 2 3/4 inches across, you could buy that one (click on the photo) and try it. Otherwise, you're stuck trying to find one. You could try contacting OZ at info@ozracing.com
Another thing you can try is using a big pipe wrench to tighten and remove the wheel cap. Put a shop rag between it and the wheel cap to avoid scratching it.</FONT>
Modified by nsxtasy at 9:34 AM 7/13/2008
Old Jul 12, 2008 | 09:28 PM
nubcake's Avatar
If you look closely at the picture, the OZ rims have a little key, which is not the center cap. I will try to get a picture of it but it is an odd key.
Old Jul 13, 2008 | 06:32 AM
nsxtasy's Avatar
H-T Order of Merit
You're right. Forget what I posted above; it appears that the "big bolt head" part of the middle of the center cap is just for looks. My bad.
Old Jul 13, 2008 | 08:51 AM
r.wright's Avatar
Default Re: O.Z. MSW Meshies: How do you take off the center caps? (nsxtasy)
does that bolt go all the way through the hub? if so then flip the wheel over and then maybe somehow drill the stud out?
and sorry i have no idea what to use. just bring the wheels to a shop or hardware store and experiment.
Old Jul 13, 2008 | 09:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: O.Z. MSW Meshies: How do you take off the center caps? (Opossum Jenkins)
Old Jul 15, 2008 | 03:00 PM
nubcake's Avatar
It's really werid, I can't find any tool to take it out.
Old Jul 15, 2008 | 03:48 PM
siblues's Avatar
My old MSW 55c's had one bolt that was a key to get the cap off it was a allen key with a small center pin in it snap on and a few higher grade tool companies make them.
Found them they are called temper proof torx bits.atleast thats what mine were on my msw's
Modified by siblues at 7:55 PM 7/15/2008
Old Jul 15, 2008 | 08:08 PM
nubcake's Avatar
Okay I've take some pictures of the hole:
Old Jul 16, 2008 | 11:52 AM
nubcake's Avatar
I want to put these on my car.
Old Jul 16, 2008 | 05:49 PM
nubcake's Avatar
It seems as though there is nothing to grap onto in the hole, I tried with some alley wrenchs and no luck.
Old Jul 17, 2008 | 04:59 PM
nubcake's Avatar
Bump
Old Jul 18, 2008 | 02:24 PM
nubcake's Avatar
Old Jul 19, 2008 | 12:14 PM
luciferi's Avatar
I had a set of fittipaldis with the same thing. Contact oz for the tool as mentioned previuosly. Or, you hammer in a larger torx or allen into it. Or, drill the head off.
Old Jul 20, 2008 | 12:53 PM
nubcake's Avatar
Contacted O.Z. a couple days ago and still no response. Do you think if I break the lock I can replce it with a regular screw or something? BTW breaking it is the last resort I want to do.
Old Jul 21, 2008 | 01:16 PM
sohcSUCKS's Avatar
i have the same rims on my car. i bought mine used and they didnt come with the screws for the center caps so i just left them off
LOL who put them sticky weights on the rim........
HonndaKidd
Feb 23, 2013 10:54 PM
mitsubishiv5
Dec 31, 2010 07:42 AM
ABCVTEC
Jul 7, 2007 09:07 AM
Ill Mitch
Apr 13, 2007 05:46 PM
SLAMMED_EF8
Mar 17, 2006 12:27 PM
