plx and s300 problemsjust bought a plx sm-afr. hooked it up through the eld and ground to the batter
just bought a plx sm-afr. hooked it up through the eld and ground to the battery. i dont have a afr gauge.
at first the o2 voltage stays around .5v and is right around 14.7 on af gauge(which is dead on from what plx instructions say) through s300. but after a little bit the voltage jumps up to .9v but the afr stays at 14.7. trying to figure out what the deal is here?
we messed with the offset of the voltage but that did nothing whatsoever.
whats the best power source through the ignition switch?? right now we are running it through the power wire on my oil psi gauge.
thanks for the help
by the way this is on a p30 ecu engine is a h22a
ninja edit: i really f'd the title up haha
Modified by sohctodohc at 8:05 PM 7/10/2008
thanks for the help
yes we are using the eld for the input. but i thought it was only the usdm ecu's you had to worry about cutting those resistors??? i might be wrong if so please correct me
hmm...welp i went ahead and ordered a bung and im just gonna run the plx as the wideband and keep the narrowbend. and go from there.
how did u figure out it was a bad output???
STi-Thrill
Jan 13, 2010 11:38 AM
