Help, car dies in neutral...
Old Jul 10, 2008 | 10:01 AM
AER6xEP3's Avatar
Default Help, car dies in neutral...
So here's the problem, it usually happens early in the morning when i'm driving to work, the car starts just fine, and drives fine when i'm in gear but as soon as I shift to neutral when comming to a stop the car doesnt idle, the rpm drops and the car dies. I have to start it up again, it happens everytime i switch into neutral. i have an 02 EP3, with about 120k miles. Anyone know what the problem could be? Thanks for the help.
Old Jul 11, 2008 | 03:54 PM
AER6xEP3's Avatar
Default Re: Help, car dies in neutral... (AER6xEP3)
BUMP, anyone?
Old Jul 11, 2008 | 05:10 PM
andyep3's Avatar
Throwing any codes?
I'm having weird neutral (and in gear) issues myself, thinking it's a sensor of some sort on my end.
Maybe something similar with yours - throttle cable too loose/tight?
Old Jul 11, 2008 | 09:42 PM
WhiteOnRice's Avatar
Sounds like the clutch won't disengage. Does it jerk the car in neutral like it's snubbing out?
Check/bleed clutch fluid.
Old Jul 12, 2008 | 04:06 AM
teamko's Avatar
Could be vaccuum line leak, poorly tuned ecu, clogged injectors, really bad oil sludge, Corrosion somewhere on the charging system power lines, what mods do you have? when did this start?
Old Jul 13, 2008 | 12:56 PM
thetunersource's Avatar
Default Re: (teamko)
simple first thing, try resetting your ecu and have it relearn
Old Jul 14, 2008 | 09:31 AM
AER6xEP3's Avatar
no it doesnt jerk or anything, its sort of a smooth kill, i'll be cruisin in neutral to a stop light, and the rpm will just slowly fall until the car dies.
Old Jul 14, 2008 | 11:16 AM
JRbuilt's Avatar
Default Re: (andyep3)
Run your codes at autozone and check the manual.
levaughnt
Honda Civic (2006 - 2015)
Jun 26, 2011 02:27 PM
sh!ft
20
May 28, 2009 03:42 PM
redcivic13
Jun 18, 2008 04:48 PM
0ni
Dec 3, 2007 02:20 AM
Harley999
Jul 8, 2004 02:52 PM
