my D16y8 engine came with a knock sensor!!!
Old Jul 19, 2002 | 03:07 PM
brcivic411's Avatar
Default edit: Do d16y8s have knock sensors?????
or so.. at least my CEL tells me. I just threw a 23 which is the knock sensor on my d16y8. Any body have a clue why? I just installed the hondata gasget.. i was behind the block alot when i was wrenching that last manifold bolt on!
thanks,
bryan
[Modified by brcivic411, 7:41 AM 7/22/2002]
Old Jul 19, 2002 | 09:51 PM
salbaje's Avatar
Default Re: my D16y8 engine came with a knock sensor!!! (brcivic411)
check on the back of the head by the intake manifold on top of the oil filter there is a plug there for knock sensor.
Old Jul 20, 2002 | 06:52 PM
brcivic411's Avatar
Default Re: my D16y8 engine came with a knock sensor!!! (salbaje)
i'm actually pretty sure my engine doesn't have a knock sensor.. just trying to figure out why i threw that code. even if there's a plug there, how could that have thrown the code unless it's tied into the ecu?
hmmm...
Old Jul 22, 2002 | 05:39 AM
brcivic411's Avatar
well, i reset the ecu, took it out for a drive, and yes, code '23' came up again. this is really interesting
Old Jul 22, 2002 | 06:05 AM
Mikey3000's Avatar
then you must not have a d16y8 ecu. do you?
Old Jul 22, 2002 | 06:16 AM
brcivic411's Avatar
Default Re: my D16y8 engine came with a knock sensor!!! (Salvatore Leone)
i do.
I haven't touched anything except pulling off the intake manifold to replace gasget.
Old Jul 22, 2002 | 06:25 AM
builthatch's Avatar
MiG-21 superfan
you have a knock sensor...its right above the oil filter, with the plug removed the sensor is green ( i think) anyway,you should get a helms manual for your engine...
Old Jul 22, 2002 | 06:42 AM
brcivic411's Avatar
Default Re: my D16y8 engine came with a knock sensor!!! (builthatch)
i do have a helms manual.. but i was always told that the D series did not have knock sensors... I'm confused
Old Jul 22, 2002 | 06:57 AM
builthatch's Avatar
MiG-21 superfan
sohc vtec does
Old Jul 22, 2002 | 06:59 AM
brcivic411's Avatar
even the z6?
Old Jul 22, 2002 | 08:23 AM
serious's Avatar
i don't believe the z6 does, though i'm not 100% sure.
what would a knock sensor be called in a helm's?
Old Jul 22, 2002 | 08:27 AM
brcivic411's Avatar
Default Re: my D16y8 engine came with a knock sensor!!! (serious)
ok, i have to confess that I was wrong.
the d16y8 DOES have a knock sensor: http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
i don't believe the d16z6 does: http://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
Old Jul 22, 2002 | 12:12 PM
jdmillusion's Avatar
on the same note brcivic. are you using an OEM head gasket? just wondering.
Old Jul 22, 2002 | 12:13 PM
brcivic411's Avatar
Default Re: my D16y8 engine came with a knock sensor!!! (jdmillusion)
yes
Old Oct 23, 2003 | 07:50 AM
Snail Tuning's Avatar
is their a way to get the knock sensor off the d16y8 to fit the d16z6?
Old Oct 23, 2003 | 09:50 AM
RyanEJ8's Avatar
Default Re: edit: Do d16y8s have knock sensors????? (brcivic411)
Y8 = knock sensor
Z6 = NO knock sensor
Old Oct 23, 2003 | 11:55 AM
turboxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 &raquo;</TD></TR><TR><TD CLASS="quote">i do have a helms manual.. but i was always told that the D series did not have knock sensors... I'm confused &lt;IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emcrook.gif" BORDER="0"&gt; </TD></TR></TABLE>
You do have a knock sensor. Check the plug ( b/w intake manifold and oil filter) you could have just knocked it loose or pulled on the wiring to the plug.
THC07
Oct 2, 2005 01:31 PM
redpeppers
Sep 15, 2005 06:42 AM
y2ks2k
May 11, 2005 02:29 PM
FormulaEJ8
Feb 8, 2003 07:59 PM
vladd
Nov 30, 2002 04:15 PM
