anyone have before and after results of a skunk2 manifold on a turbo ls?
Old Jul 19, 2002 | 02:44 PM
JM Performance's Avatar
Default anyone have before and after results of a skunk2 manifold on a turbo ls?
either numbers or at least butt dyno.
Old Jul 20, 2002 | 07:44 PM
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (00SilverLS)
no body?
Old Jul 20, 2002 | 08:45 PM
PrecisionH23a's Avatar
http://www.skunk2.com/start.htm
Engine>Intake Manifold>Dyno Tests
B18C + Skunk2 Racing Stage I VTEC Cams + Skunk2 Racing Manifold 180.7 hp
B18C + Skunk2 Racing Stage I VTEC Cams 169.9hp
B18C stock 157.6hp
So minus the vtec cams, youre looking at about 10.8hp, but then again you have to take into account the vtec cams will help the performance of the manifold also... i know it isnt a turbo LS, but you get some kind of idea of what itll do for you.
[Modified by GudeH23a, 12:51 AM 7/21/2002]
Old Jul 21, 2002 | 12:56 AM
SIK IN DA HED's Avatar
New User
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (GudeH23a)
if you find out... let me know. i always wanted to see how the skunk2 intake manifold helped out ls turbos.
Old Jul 21, 2002 | 06:52 AM
89civic1.8T's Avatar
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (dlplayboy)
I am thinking of usign a JG intake Manifold on my LS. I would be interested to see how the two will do against each other. I know the stock LS manifold is very restricted at the casting point on the runners.
Old Jul 21, 2002 | 01:19 PM
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (89civic1.8T)
i heard the jg was designed for 7000+ rpm. Sounds like it might not be suited that great for an LS..
Old Jul 21, 2002 | 02:12 PM
Mase's Avatar
hrmm, i have the skunk2 IM on my b18b, but sorry i got it before the turbo, however i will say, I like it, and did feel some gains from it even when i was N/A...
Old Jul 21, 2002 | 02:44 PM
TurboInteg95's Avatar
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (CDooMe2)
i had it on my car as well but I also had it before the turbo. However, if you just look at the design of the manifold and compare them, it cannot be any worse then the LS manifold. I say go for it.
Old Jun 13, 2003 | 06:26 AM
glagola1's Avatar
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (TurboInteg95)
Unless you are revving your ls to at least 8000 rpms it's not worth it. It kill bottem end! I sold mine a week after I installed it.
Old Jun 13, 2003 | 07:36 AM
DIRep972's Avatar
Smarter than you
Default Re: anyone have before and after results of a skunk2 manifold on a turbo ls? (glagola1)
For racing. i love it. I think its much better then the LS. Car pulls harder top end and I can squeeze some extra revs out of it. The car has less power in the midrange which is actually kinda good cause I can hit gears harder when going from 1st-2nd and it wont spin like it used too with all the LS midrange. I have a little more lag then I used too but overall I think its better in the long run if u wanna make good power on an LS street car.
ernald711
Apr 19, 2005 11:41 AM
SOHCVTECx2
Jul 13, 2004 04:03 PM
Just2Fast
Feb 5, 2003 08:17 AM
LOwrestling2001
Apr 8, 2002 02:39 AM
