Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question
Old Jul 9, 2008 | 06:40 PM
vacantskies88's Avatar
Default Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question
Hey guys
Tonight I was installing my some parts onto my B18C1 but I'm having clearance problems between the ITR throttle cable bracket and the Pro-Flo fuel rail. I'm using the spacers for the fuel rail and everything else seems to be aligned correctly but the two are in the way of each other.
I tried installing one before the other both ways but I'm still having problems getting everything to sit right. I can only get the left side throttle bracket bolt in.
I'll have pics up shortly
Thanks in advance
Modified by vacantskies88 at 2:52 PM 7/10/2008
Old Jul 10, 2008 | 10:52 AM
Default Re: Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question (vacantskies88)
Pics are up, still need help
Old Jul 11, 2008 | 09:30 AM
Godspeed07's Avatar
looks like if you could bend the thing in the opposite direction and flip the bracket around, it might fit..........i wouldn't recommend doing that though. Personally id try to find a shop that would custom me a bracket, or see what the ITR one looked like......sorry to not be much help....good luck though.
Edit: have a piece of steel welded to it and re drill..???? shouldn't cost much
Old Jul 11, 2008 | 07:42 PM
Default Re: Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question (Godspeed07)
I am running the ITR throttle cable bracket...
Old Jul 18, 2008 | 06:54 AM
JakeSpec's Avatar
make your own bracket. wont take much
Old Jul 18, 2008 | 09:30 PM
gsrcrazy's Avatar
Default Re: Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question (JakeSpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote">make your own bracket. wont take much</TD></TR></TABLE>
X2
off topic_JakeSpec! I think ur bro was the one that sold me my arp head studs thx!
back on topic help this guy out!
Old Jul 19, 2008 | 06:46 PM
JDCIVIC's Avatar
I had the same issue, I just made a square aluminum plate and drilled holes for the bracket and manifold..basically i raised up the throttle bracket slightly to line it up right..
Old Jul 19, 2008 | 08:45 PM
JakeSpec's Avatar
Default Re: Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question (gsrcrazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcrazy &raquo;</TD></TR><TR><TD CLASS="quote">
X2
back on topic help this guy out!</TD></TR></TABLE>
Cool
3 people say just make it already !
Old Jul 20, 2008 | 07:17 AM
Slystone's Avatar
like my SK2 youv got to make your own cable braket older!
snowpro127
Dec 7, 2009 10:41 AM
vacantskies88
Jul 10, 2008 04:31 PM
BlueShadow
Oct 30, 2005 11:33 AM
