Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Problems with Skunk2 rear camber plate bushings
Old Jul 9, 2008 | 04:34 PM
Dracomeister's Avatar
Default Problems with Skunk2 rear camber plate bushings
OK guys, here's the drill. I put the HFP suspension on my '07 Si and didn't like the negative camber (I autocross the car) so I put a set of Skunk2 plates on the rear, set the suspension at 0 negative camber, 0 toe, and the car could be forced into moderate oversteer. Worked great.
Jump forward 6 months & 3000 miles. While changing the rear rotors last night I noticed a LOT of play in the rear suspension, both sides. I pulled the upper control arms (Skunk2) and found the bushings on both end wallowed out. I had used the lubricant supplied with the arm kit so I'm at a loss of why the bushings died in 6 months. Any ideas or did I just screw up the installation ???
Old Jul 9, 2008 | 08:17 PM
icrashed's Avatar
Default Re: Problems with Skunk2 rear camber plate bushings (Dracomeister)
I have the same problem and have contacted Brian from Skunk2 on 8thcivic.com via PM's. He suggested that i take pictures of the problem area and send them to him. This was about 2 months ago and i have yet to actually do this. You may have better luck on 8thcivic contacting him. Please due keep us updated here if you take any action towards the problem.
Old Jul 10, 2008 | 01:39 PM
Zeusone's Avatar
they had a problem with them. the some older kits were defective.
HuchNet
Suspension & Brakes
Jan 13, 2012 11:56 AM
etank82
Aug 28, 2010 08:32 AM
Pworld925
Suspension & Brakes
Aug 11, 2010 01:52 PM
chino369
Suspension & Brakes
Jul 20, 2006 08:22 AM
GreenBean
Nov 29, 2002 06:29 AM
