Best aftermarket Valvetrain for LS VTEC
Old Jul 19, 2002 | 02:02 PM
Full Race EG's Avatar
Default Best aftermarket Valvetrain for LS VTEC
I am posting this for a friend. He has a 1993 Civic Dx 2 door coupe. He hydrolocked his motor and is now going to go LS VTEC. He is going to have a GSR block with a JDM B16 head and type r cams. He will be using LS pistons, rods, and the ls crank. He needs a new valve train for the head. What kind of valve train shoud he buy? Any suggestions would be appreciated.
[Modified by IntegraLStuner, 11:03 PM 7/19/2002]
Old Jul 19, 2002 | 06:43 PM
bruthaboost's Avatar
Default Re: Best aftermarket Valvetrain for LS VTEC (IntegraLStuner)
He won't be able to really take advantage of the R cams unless he bumps up his compression to > 10:1. Also since your'e using R cams, just use the R valve springs.
Old Jul 20, 2002 | 02:52 PM
Vanilla4215's Avatar
Default Re: Best aftermarket Valvetrain for LS VTEC (bruthaboost)
gsr+b16 head=low compression bad for all motor
If he is going to stick with the R cams, you could get in R inner and outer springs. Or portflow springs, with R springs. Maybe the retainers should be upgraded to.
4DR_EK
May 10, 2010 09:43 PM
slowr6
Mar 8, 2007 10:50 PM
cxVtecC1
Nov 14, 2004 07:28 PM
91ls-v
May 20, 2004 03:49 AM
