gas gauge?
so the reading is incorrect...what to check? the cluster i got was a working one from a homies wreck si same for the sending unit...can i reposition the needle to qtr tank and see what happen or will that mess up anything?
Its all done by electrical, i have change the actual gas/temp unit many times on mine.
You can adjust it, cause when you turn back on it will rise to where it was.
Im assuming you float is stuck.
Your going to need to drop the tank and check out the float and make sure it doesent get stuck.
you might be able to pull the face off of the gauge cluster and move the needle down to where it should be and it will relearn the sending unit... Not sure if it will work for you but it does on the preludes
Hiroshima_VTi-S
May 30, 2007 10:35 PM
