H22a H23a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">93-97 H22 50mm
98-01 H22 55mm
H23a 55mm</TD></TR></TABLE>
great info. i always assumed 50mm
might be my next starting point
98-01 H22 55mm
Just check the part numbers they should be the same. Its probably more simple and cheaper to just get h23a crank and rods and put them in an h22a assuming u can get an h22a block for cheap. If you run jdm h22a pistons with the h23 crank you will yield about 11.7:1 compression with type s pistons its around 12.2:1. The f22b crank and rods are the same parts as the h23 crank and rods that might be cheaper and easier to get as well.
XES
Jun 7, 2008 07:22 AM
