a great flood and a dead starter.
Old Jul 9, 2008 | 07:05 AM
puertoricanboy90's Avatar
Default a great flood and a dead starter.
I accidentally hit a flooded area with about sixteen inches of water while going forty mph...and my car has about three inches of ground clearance... therefore you can imagine the forces exerted on my car and that water got into everything. after about ten min i turned on my car and it sounded like a tractor and wouldn't go very fast. it stalled trying to back into the garage. and it wouldn't turn on aggain. i think i fried my starter cuz for ten min i just cranked the sucker. and now my car won't turn on. there is no hearing the solenoid click when i turn the key. if my starter is dead, would it prevent my car from being push started in gear? my battery charge is sufficient 13.5 v. help? what all does the starter affect?
Old Jul 9, 2008 | 07:10 AM
sirtef9's Avatar
Default Re: a great flood and a dead starter. (puertoricanboy90)
You wish it was the Starter. your motor is gone sry to say bro ham!
Old Jul 9, 2008 | 08:02 AM
rbwdriven's Avatar
you hydrolocked your engine. pull a plug and spin engine and see how much water comes out from the spark plug hole.
Old Jul 9, 2008 | 08:08 AM
Default Re: (rbwdriven)
what all does hydrolock mean? should i just try to turn the cam wheel?
Old Jul 9, 2008 | 10:15 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
you've probably got a beer cans worth of puddle water in your cylidner. Water doesn't compress, so therefore the reason you burned out your started, possibly damaged your flywheel and maybe bent a rod / other nightmarish **** in your motor. Sounds like you're done.
GioTreto
Feb 4, 2016 09:31 AM
bow tie
Dec 13, 2007 12:46 PM
98gsrTEG
Aug 1, 2005 06:30 PM
DAYUIZ
Jan 20, 2004 03:03 PM
