kcjohnnyboy's Daily Sedan and Project
Here is my daily driver Honda Civic sedan. I'm pretty much done with adding parts to the outside, I'm satisfied with it. Some engine appearance upgrades will be added once I get time. Until then, here are some pictures
Comments are welcomed
Looks pretty good. MFactory products =
I think just fix that fender and body match the grille trim piece and DIY black headlight housings and it would be hard
id ditch the fake front lip.
grill looks ok.
sus and rear combo looks good.
good start...id pick up an sir lip since you're slammed. they are polyurethane so they wont fck up. that one you have now will crack easy since its abs. just a little info.
grill looks ok.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brice.Hayden »</TD></TR><TR><TD CLASS="quote">cheaper is clearly not better. lip looks like ***
.</TD></TR></TABLE>
ctr lip, no? or is that a replica?
Anyway i like it a lot, especially that rear end. Looks better than the 96-98 imo.
.</TD></TR></TABLE>
it's a CTR replica front lip. i like the way it sits as black because it matches my side moldings and skirts so it will stay black. and, the fender, i have yet to find an oem silver one to replace it.
Red/Clear tails, SI front end and some JDM Visors "or replicas for $39.95" would really set that thing off..!!
Modified by 1CaMw0nDeR at 11:01 PM 7/13/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CaMw0nDeR »</TD></TR><TR><TD CLASS="quote">Where'd you get the wrinkle red paint from..?? VHT online..???</TD></TR></TABLE>
I got the wrinkle paint at my local O'Reily's Autoparts store.
Thanks for the comments guys, its coming along nicely and the way I would like it to be. I also did the map light install on it also just earlier today
yeah, and they are not all the way down in the front and rear, still have about 18 clicks or so to go in the front and ten in the rear. i would go lower but my b pipe on my apexi catback is already half an inch off the ground
r4adkshn1
Feb 24, 2003 02:31 PM
