it worked!!!!! changing the tranny fluid stopeed the grind thanks you everyone
Your Welcome!
i couldn't believe it fixed mine either, but it hasn't come back in 6 months of hard driving!
i had my car 6 months before i started getting any symptoms,
right around 45,000 miles it started grinding,
but it got so bad i thought i'd be doing tranny work/tranny swap
i'm glad it worked for you also!
i used honda MTF- dealer prices... oh well, IT WORKED!
---just some more heads up---
i searched this problem for about a month before i did it...
i shouldn't have waited that long- it was starting to grind in other gears sometimes.
but i didn't find any shavings or anything- which was a relief!
i have heard many others say- "it will come back..."
and others replying- i change mine every 10,000 miles, and i dont have the issue...
mine has done it a few times- but only when i was in a hurry, and i forget to warm them up/lube them before driving...
if i do the 1,2,3,4,3,2,1 trick every time, its perfect!
Good Luck!
Good Luck!
Just a drain and fill.... i tip mine a little both ways to get more or less out
https://honda-tech.com/zerothread?id=2155139
easy "how to" link /\
GM synchromesh Friction modified is no longer made as ive read around.
luckily, honda's new Manual transmission fluid is very much like GM's synchromesh. green bottle, white cap.
i changed the fluid in my EP with 62K miles on it and the tranny feels damn smooth and fluid. None of that notchiness that you get in 2nd n 3rd.
Is this thread really necessary? You could have just PM'd those who helped you out, at least.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S »</TD></TR><TR><TD CLASS="quote">Is this thread really necessary? You could have just PM'd those who helped you out, at least.</TD></TR></TABLE>
Was your post really necessary?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20sedan »</TD></TR><TR><TD CLASS="quote">
Was your post really necessary?</TD></TR></TABLE>
how much is each bottle of the new honda mtf anyways?
nevermind. found it for 6 dollars each at inlinefour. all the stealerships around here wanted more than 6 dollars per bottle.
Modified by eMpAtHy at 7:03 PM 7/16/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAKAYAMA IMPORTS »</TD></TR><TR><TD CLASS="quote">bump for you lol</TD></TR></TABLE>
Why bump? Seriously...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S »</TD></TR><TR><TD CLASS="quote">^ I think this is where b20sedan comes along and will comment, "Why post? Seriously..."
Exactly, it happened two days ago? What does it matter, does a bumped thread really disrupt this low traffic RSX/EP3 forum? Seriously, just let it go.
... Wait, I fell into your trap; I should have just let it go as well and not responded ... I’m caught in paradox now. What a hypocrite I have become.
</TD></TR></TABLE>Exactly, it happened two days ago? What does it matter, does a bumped thread really disrupt this low traffic RSX/EP3 forum? Seriously, just let it go.
Exactly, it happened two days ago? What does it matter, does a bumped thread really disrupt this low traffic RSX/EP3 forum? Seriously, just let it go.</TD></TR></TABLE>
I was about to respond back to what you had to say here until I read this below...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20sedan »</TD></TR><TR><TD CLASS="quote">... Wait, I fell into your trap; I should have just let it go as well and not responded ... I’m caught in paradox now. What a hypocrite I have become.
After reading it, I laughed, out loud.
</TD></TR></TABLE>After reading it, I laughed, out loud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20sedan »</TD></TR><TR><TD CLASS="quote">Exactly, it happened two days ago? What does it matter, does a bumped thread really disrupt this low traffic RSX/EP3 forum? Seriously, just let it go.</TD></TR></TABLE>
The hypocrisy in this statement annoys me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">
The hypocrisy in this statement annoys me.</TD></TR></TABLE>
Then why read it?
j/k
Then why read it?
j/k
Rikaro
10
Jun 6, 2007 04:38 PM
