Someone help that's good with radiator fluid change...(working on it now)
Old Jul 19, 2002 | 11:59 AM
Turtle's Avatar
Default Someone help that's good with radiator fluid change...(working on it now)
Ok, 35,000 miles on the car, however when I checked the fluid it was running a rich mixture (not sure if this would be the correct term), but basically too much rad fluid, not enough water. So i go to change it (with trusty helms in hand ).
Here is the question. Where is the drain plug for the engine...I can't seem to find it!
Also, this was quite a messy job...is there tips that you have to keep from spilling chit everywhere!
Thanks for the help.
Brandon - who is sitting patiently for the answer to appear before he contiues...
Old Jul 19, 2002 | 12:00 PM
Reid's Avatar
Global Moderator
Default Re: Someone help that's good with radiator fluid change...(working on it now) (401-2001)
The drain is on the bottom of the radiator.
Old Jul 19, 2002 | 12:02 PM
Dave-ROR's Avatar
Default Re: Someone help that's good with radiator fluid change...(working on it now) (Reid)
he asked for the drain plug on the engine, not radiator, read you n00b!
it's behind the header on the exhaust side of the block.
there's pics when we did my car.
http://www.bseries.net/html/garage/thermo.php
Turtle's Avatar
Drain plug for the engine coolant...
Brandon - who thought he was the only in the house.
Old Jul 19, 2002 | 12:04 PM
Turtle's Avatar
Default Re: Someone help that's good with radiator fluid change...(working on it now) (Dave-ROR)
Dave...thanks...you FL people rock the house.
Old Jul 19, 2002 | 12:09 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
there's
unless you're working on an rx-7 like my old one with NO DRAIN ON THE BLOCK.
pos mazda. :\
Old Jul 19, 2002 | 12:10 PM
Dave-ROR's Avatar
Default Re: Someone help that's good with radiator fluid change...(working on it now) (SkyeC)
there's
pos mazda. :\
But then again Skye, this is a *HONDA* msg board. See my sig? New RX7 project has started.. lol thinking about getting a 5spd cressida and putting in a 6MGE motor with a CT26 snail bolted up..... <eg>
BB4lude
18
Mar 10, 2008 05:10 PM
skata89
Oct 2, 2005 04:38 PM
scrubachu
Feb 6, 2003 01:32 PM
deftones0817
Nov 18, 2002 01:56 PM
TurbothisLS
Oct 6, 2002 05:19 PM
