My First Build
Well finally im going to build a Honda. This is my first build so please no bashing. Suggestions and your positive input are welcome. This isnt something I just threw together as an idea. I did alot of research before choosing parts.
<U>Block</U>
B18A Stock Sleeves
LS Crank
CTR Crank Pulley
ACL Race Bearings
LS Rods Shot Peened
ARP Rod Bolts
JDM ITR Over Sized Pistons
Golden Eagle Block Guard
ARP Head Studs
OEM Head Gasket
ITR Oil Pump
OEM Water Pump
<U>Head</U>
B16 Stock Port
Crower Valve Train
OEM ITR I&E Valves
Crower Stage 2's
Hondata IM Gasket
Skunk2 Pro Series IM
Skunk2 68mm TB
DC Sports JDM 4-1 Header
Toda Timing Belt
Skunk2 Cam Gears
<U>Trans</U>
Cable LSD B16
CC Stage 3
CC Light Weight Steel Flywheel
Tuned on S300 in a CRX
According to the Zeal Auto Werks Honda Compression Calculator, compression should be around 12.3:1. Hoping to put down a reliable 220whp.
Modified by VolkswagenWHO!!! at 3:24 PM 7/8/2008
<U>Block</U>
B18A Stock Sleeves
LS Crank
CTR Crank Pulley
ACL Race Bearings
LS Rods Shot Peened
ARP Rod Bolts
ARP Head Studs
OEM Head Gasket
ITR Oil Pump
OEM Water Pump
<U>Head</U>
B16 Stock Port
Crower Valve Train
OEM ITR I&E Valves
Crower Stage 2's
Hondata IM Gasket
Skunk2 68mm TB
Toda Timing Belt
Skunk2 Cam Gears
<U>Trans</U>
Cable LSD B16
CC Stage 3
diogolucindo
Dec 13, 2009 01:49 PM
