b16 cable clutch disc, where to find one??
Old Jul 8, 2008 | 03:23 AM
95dc2teg's Avatar
Default b16 cable clutch disc, where to find one??
Hey guys im need of a clutch disc for my 92 civic with a b18b1 swap and b16 cable transmission. I have found out the a normal b-series pressure plate will work, so that i already have, but the clutch disc is different because the input shaft coming from the transmission is smaller. is this correct?? If so where can i get a b16 cable clutch disc for cheap? im looking for a pucked clutch, and NOT a street disc. Thanks!!
Old Jul 8, 2008 | 03:32 AM
Furyof4's Avatar
Default Re: b16 cable clutch disc, where to find one?? (95dc2teg)
Any clutch disc for a 90-91 integra will work.
Old Jul 8, 2008 | 11:38 AM
95dc2teg's Avatar
Default Re: b16 cable clutch disc, where to find one?? (Furyof4)
thanks for the post! can anyone else verify this?? also can i still use the Pressure plate i have (b-series hydro)??
and what last thing what is the difference between the clutch disc for a cable and hydro trannies?
Old Jul 8, 2008 | 12:17 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">Any clutch disc for a 90-91 integra will work.</TD></TR></TABLE>
Correct, that is what I used when I had the B16 cable tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the post! can anyone else verify this?? also can i still use the Pressure plate i have (b-series hydro)??
and what last thing what is the difference between the clutch disc for a cable and hydro trannies?</TD></TR></TABLE>
The difference is the spline count on the clutch disc, if I remember correctly.
Old Jul 8, 2008 | 12:30 PM
sirtef9's Avatar
Default Re: b16 cable clutch disc, where to find one?? (EL Vap133)
ACT sells the discs you need.
Old Jul 8, 2008 | 02:40 PM
95dc2teg's Avatar
Default Re: b16 cable clutch disc, where to find one?? (sirtef9)
alright sweet thanks guys! so all i have to do is replace the clutch disc i have with the right one and keep the pressure plate and im set! i appreciate it guys!
Honda_Fanatic
Aug 14, 2012 10:41 AM
hammergunner
Aug 31, 2008 01:23 AM
gtfour43
Jul 16, 2004 08:12 AM
qwksi1
Feb 8, 2004 07:50 AM
mraudio13
Apr 2, 2003 11:01 AM
