are all D-series fuel rail the same?
Old Jul 8, 2008 | 01:48 AM
sickeswrx's Avatar
Default are all D-series fuel rail the same?
hi, i have a 94 civic vx that i need a fuel rail for. i was wondering if i need the specific vx fuel rail or i can use any D-series fuel rail. thanks in advance.
Old Jul 8, 2008 | 06:32 AM
riceburner700's Avatar
Default Re: are all D-series fuel rail the same? (sickeswrx)
you can use any fuel rail from a 92-95 and it will bolt right up, if you go with a 96+ you will need the FPR as well. dont know about the 88-91 though
Old Jul 8, 2008 | 06:54 AM
JRTegman987's Avatar
ive got a fuel rail off a z6 if ur interested
Old Jul 8, 2008 | 08:02 AM
thumper64's Avatar
I heard that you can't use a 1.5L fuel rail on a 1.6, though I can't imagine it being an issue the opposite way.
The JDM cars use a slightly different fuel rail than USDM, though they are identicle in every way aside from the fuel inlet. Also, 92-95 rails have a different bolt pattern than 96-00. 92-95 have 3 bolts, and 96-00 have 2.
Old Jul 8, 2008 | 08:34 AM
slvrcvc93's Avatar
Default Re: (thumper64)
as long as its a 92-95 doesn't matter on the 96-00 the fuel pressure regulator is positioned different.
Old Jul 8, 2008 | 12:16 PM
sickeswrx's Avatar
Default Re: (slvrcvc93)
alright cool. thanks a lot guys. ill borrow a fuel rail from my friend. just wanted to make sure i have everything before i start doing the swap. thanks again!
ghostriderinnc
Jul 31, 2010 09:38 AM
Redemption
Free Stuff
Feb 13, 2009 11:47 AM
sohc1200cc
Nov 3, 2006 10:02 AM
dohdoh420
Nov 23, 2005 05:25 PM
11mastamind11
Apr 25, 2005 10:05 AM
