DOHC ZC problem???
Old Jul 7, 2008 | 08:47 PM
SIR EF9's Avatar
Default DOHC ZC problem???
Well let me get to the point...
1.the car turns on wen it wants to...
2. it idles alot...
3.wont pass 3000 RPMs even if u punch the gas all the way in....
need help to fix it...
please help need to get it running.....
Old Jul 7, 2008 | 08:51 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: DOHC ZC problem??? (SIR EF9)
Any codes?
Old Jul 7, 2008 | 08:56 PM
SIR EF9's Avatar
Default Re: DOHC ZC problem??? (***$nyper)
it shows the distributor code...
but i fixed it....
i put a new one,....
Old Jul 7, 2008 | 10:29 PM
Shermanef9's Avatar
I had this same problem, but it fixed itself with a restart.
im certain its an ECU problem
Old Jul 7, 2008 | 11:36 PM
DCRB's Avatar
how's your cat look?
Old Jul 8, 2008 | 01:23 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: (DCRB)
Had a similar problem, turned out to be bad cap/rotor.
Old Jul 11, 2008 | 02:06 AM
likwid2u's Avatar
i had the same problem with mine and it happen to be the dirty *** fuel filter i just connected the fuel line direct from the fire wall to the fuel rail and it worked then i bought a new filter
Old Jul 11, 2008 | 10:21 AM
wiZCo's Avatar
Stouts 'n' Scotch
It's been said before, but try to clear the code out by resetting your ECU. You're in limp mode because of the code.
If that doesn't work, try the cap and rotor. BTW, you said "distributor code" and there are a few of them. Which one was it exactly?
Old Jul 11, 2008 | 08:46 PM
SwissChEz82's Avatar
Default Re: (wiZCo)
Also consider pulling the injectors and letting them soak in injector cleaner, minus the electrical connections.
onlydrivesi
Oct 24, 2014 05:35 PM
92jdmhatch
Apr 26, 2008 05:10 PM
vtectuner2204
Oct 27, 2006 07:36 AM
EF'n
Sep 16, 2002 07:19 PM
FUP23
Aug 7, 2002 12:57 PM
