Someone wanna explain vtec to me?
Old Jul 19, 2002 | 10:56 AM
Audi2Honda's Avatar
Default Someone wanna explain vtec to me?
I got a new honda here and I hear Vtec this and Vtec that. I heard some guy talk about his car going into Vtec?
I've got an 02 3.0 Vtec and am not sure what the fuss is about. I know in general honda engines like high revs and so far I haven't gone much past 3000-3500 (breakin period)
Old Jul 19, 2002 | 11:36 AM
greensleeper's Avatar
Default Re: Someone wanna explain vtec to me? (Audi2Honda)
VTEC - variable timing and lift electronic control
there's three kinds of VTEC these days. SOHC VTEC, DOHC VTEC, and the new iVTEC. Not sure which the V6's operate with but its probably similar to the SOHC VTEC which only affects the intake valves. At a programmed point int he RPM band (the cross over point) a hydraulically activated pin engages a larger cam lobe which throws you into VTEC.
need more?
Old Jul 19, 2002 | 11:41 AM
Audi2Honda's Avatar
Default Re: Someone wanna explain vtec to me? (greensleeper)
So basically at a certain point in the RPM band the fuel/air mixture changes dramitcally and timing is automatically adjusted to give more hp?
Old Jul 19, 2002 | 11:46 AM
YeuEmMaiMai's Avatar
Vtec uses oil pressure to lock the cam into a "Wild" racing profile when you excede a certain RPM. It gives you a few extra HP while keeping your low RPM engine speeds fuel efficient.
The V6 is a SOHC Vtec the 4's are either SOHC or DOHC and the new civics use a 3 stage Vtec allowing wild cams at the top, normal in the middle and ultra lean for max fuel ecomomy on the bottom. I have heart A/F mictures in the order of 20 to 1
if you want to know about it in detail go here
http://www.leecao.com/honda/vtec/index.html
Old Jul 19, 2002 | 11:53 AM
KGAccord's Avatar
Default Re: Someone wanna explain vtec to me? (YeuEmMaiMai)
Wild cams!
The hi cam profile on a SOHC VTEC is still more for economy than racing. Now the Type R cams or Prelude Type S cams are more like race cams. They are certainly not wild.
Old Jul 19, 2002 | 11:58 AM
Default Re: Someone wanna explain vtec to me? (KGAccord)
i was just referring to the explanation that the guy on the Vtec site gives
Old Jul 19, 2002 | 12:55 PM
carolinaACCORD's Avatar
here ya go, this explains it all. j/k
[Modified by carolinaACCLUDE, 4:55 PM 7/19/2002]
theVTEClife
Honda Civic (2001 - 2005)
May 20, 2008 05:03 PM
eumoria
45
Oct 13, 2004 11:47 AM
xvracing
May 1, 2004 01:49 PM
SOHC_MShue
Sep 18, 2002 09:27 AM
