What to do - 4 big injectors for 8 550's?
Old Jul 19, 2002 | 10:45 AM
SpeedMonkeyRacing's Avatar
Default What to do - 4 big injectors for 8 550's?
I have 4 550's right now. But most likely i will crave for more power soon...so should i go w/ 4 big injectors or go w/ 4 550's? I have hondata now but I'm switching to ems and i was told ems can support up to 8 injectors. now...wouldn't it be better to use 8 for fuel economy reason (the last 4 only sprays when needed).
what do ya think?
Jeff-
Old Jul 19, 2002 | 12:41 PM
Coldsi's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (Corporal-Jeff)
You'll still be using the same amount of fuel regardless if you have 4 or 8 injectors.
Old Jul 19, 2002 | 12:58 PM
ion_four's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (Coldsi)
not at idle and light load. the 8 smaller injectors would use less.
Old Jul 19, 2002 | 01:44 PM
Default Re: What to do - 4 big injectors for 8 550's? (ion_four)
well, on rx7's...they use two small injectors and two additional big injectors..i suppose it works that way on hondas too
Old Jul 19, 2002 | 01:47 PM
CovertFI's Avatar
i say 8 but what the hell do i know. i dont even have my dsm 440's yet
Old Jul 19, 2002 | 02:03 PM
Canuk_SiR's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (CovertFI)
I'd say if you can utilize an ems to run everything, then go with the 8
Old Jul 19, 2002 | 07:08 PM
kidkutz's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (Canuk_SiR)
i would go with 8. i was considering the same because idling would be easier. the only thing holding me back was having the manifold modified to accept a second rail...$$$.
Old Jul 19, 2002 | 07:24 PM
integra-modder's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (kidkutz)
or just get a two rail manifold.... JG/Edlebrock Victor X Manifold Group Buy
Old Jul 19, 2002 | 07:29 PM
kidkutz's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (integra-modder)
that would be a good solution...
too bad one wasn't available for my car.
Old Jul 19, 2002 | 07:30 PM
kidkutz's Avatar
btw...can hondata do 8 injectors?
Old Jul 19, 2002 | 07:31 PM
i think it can too..but i have 2b...hate the idea of needing 4b to tune so..ems i come!
Jeff-
Old Jul 19, 2002 | 07:33 PM
kidkutz's Avatar
good idea...i spoke to the tech's at AEM about the EMS running 8 injectors and they were VERY convincing...so many ways to control injectors 5-8...it's CRAZY!
Old Jul 19, 2002 | 09:00 PM
any pros and cons about this setup?
Jeff-
Old Jul 19, 2002 | 09:32 PM
ekb18c's Avatar
Dude, you dont need 8 injectors man. You can run (4) 1000 cc and still get some good gas mileage. It's all about the tunning!
Old Jul 19, 2002 | 09:47 PM
earl's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (ekb18c)
Just run 4 of the 720cc Greddy injectors. Cheaper than RC's and will work from idle to 550 whp if tuned properly.
Old Jul 20, 2002 | 01:35 PM
AE86's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (earl)
i also think you'll be better off running with 4 injectors...
Old Jul 20, 2002 | 02:19 PM
kidkutz's Avatar
tuning 1000cc injectors isn't the simplest thing in the world
i'm not saying 8 injectors is the best idea...but it sure makes the car more discreet while sitting at a light
[Modified by kidkutz, 6:27 PM 7/20/2002]
Old Jul 20, 2002 | 05:30 PM
ekb18c's Avatar
How is having 8 injectors more discreet then having 4 high flow injectors? My motor idles like a factory honda with 720cc injectors.
Old Jul 20, 2002 | 05:40 PM
kidkutz's Avatar
well he's asking about 8x550cc injectors. so i'm assuming he needs more fuel than say 4x720cc. something along the lines of 1000-1100cc
Old Jul 20, 2002 | 05:43 PM
yes...4 550's and 4 720's or bigger later on...
like how rotoary and volkswagen guys do...
better idling and better fuel consumption
Jeff-
Old Jul 20, 2002 | 05:45 PM
ekb18c's Avatar
720cc is a lot of fuel already, however I guess the most important question is how much HP is corporal jeff planning to make.? If he's planning to make 400-450 whp then 4x 720cc will be fine.
Old Jul 20, 2002 | 05:51 PM
read my signature and you'll know what i'm planning to make
right now...400~450 will do (getting it done as we speak)..but soon will switch to gt35 turbine and go all out....sponsors anyone?
Jeff-
Old Jul 20, 2002 | 07:57 PM
JM Performance's Avatar
jeff...your on the right track!
Old Jul 20, 2002 | 08:05 PM
BoostinDC2's Avatar
Default Re: What to do - 4 big injectors for 8 550's? (00SilverLS)
i would just run 4 100cc's
Old Jul 21, 2002 | 03:21 AM
i hope so...now after this..time to upgrade all other crap. damn it matt...more money spending!
Jeff-
