Disc brake question...
Old Jul 7, 2008 | 05:25 PM
Hookeduphatch's Avatar
Default Disc brake question...
doing a rear disc brake conversion on my 93 CX hatch. I got rear trailing arms, rotors, calipers, and ebrake cables from a 90 integra. I ordered steel brake lines for a 99-00 civic ex. Now i am questioning my desicion on the brake lines.
Did i get the right ones???
Old Jul 7, 2008 | 05:44 PM
hotrod99's Avatar
Default Re: Disc brake question... (Hookeduphatch)
nope,your supposed to use the brake lines from a 90-93 integra,the civic lines wont bolt up to integra calipers
Old Jul 7, 2008 | 07:53 PM
BlueIntegraBoy's Avatar
90-01 Integra, 93-97 Del Sol Si/VTEC, 92-95 Civic EX ABS/Si, or 99-00 Civic Si all fit
Old Jul 8, 2008 | 06:28 AM
Default Re: Disc brake question... (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">90-01 Integra, 93-97 Del Sol Si/VTEC, 92-95 Civic EX ABS/Si, or 99-00 Civic Si all fit</TD></TR></TABLE>
Thats what i thought. Anything with rear discs should work. Thanks!
Old Jul 8, 2008 | 08:07 AM
EL Vap133's Avatar
Default Re: Disc brake question... (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">nope,your supposed to use the brake lines from a 90-93 integra,the civic lines wont bolt up to integra calipers</TD></TR></TABLE>
Wrong, any rear disc lines will bolt on whether it is (CRX Si, Civic EX, Civic Si, Integra, Del Sol w/rear discs).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hookeduphatch &raquo;</TD></TR><TR><TD CLASS="quote">doing a rear disc brake conversion on my 93 CX hatch. I got rear trailing arms, rotors, calipers, and ebrake cables from a 90 integra. I ordered steel brake lines for a 99-00 civic ex. Now i am questioning my desicion on the brake lines.
Did i get the right ones???</TD></TR></TABLE>
Did you get the ones for an EX w/rear disc brakes?
Old Jul 8, 2008 | 08:54 AM
OMGWTFBBQ!'s Avatar
When I went to Integra RS rear discs on my ek coupe, I bought stainless steel lines for a 99-00 SI, not an EX. They fit well, but the lines were too long in the front, so I actually had to wrap them around the shock to avoid looping line.
oldskoolaccord
Mar 13, 2007 03:42 PM
miguelv0723
Nov 9, 2006 11:09 AM
FGride
May 7, 2006 10:22 PM
EJ8VTEC
Aug 6, 2005 11:23 AM
bensonwrx
11
Aug 9, 2003 04:23 PM
