Instrument cluster. (1996 2dr 5speed)
My tach/speedo/oil gauge/check engine/ etc. does not work when the car is on.
i bought the car this way, all that works are the blinker lights.
everything is plugged in behind the cluster. I dont even see a fuse for them
Did you actually get to the point where you saw the 4 screws holding the cluster to the back dashboard? I just fix my 96 ex 6 cyl with a used speedometer from ebay. You can try solder the joints of the printed circuit boards. There is a detail writeup in FAQ on how to do it.
I took it all the way out and replaced it with another one from a junk yard. Still nothin... where is the fuse, or relay to the gauges? i've been told there is one.
Endless
Nov 17, 2002 09:44 PM
