obd0 to obd1
you will need the ecu conversion harness,obd1 distibutor,obd0-1 distibutor connector,4wire oxygen sensor and connector,and a obd1 ecu...boomslang and rywire make kits for the conversion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 »</TD></TR><TR><TD CLASS="quote">you will need the ecu conversion harness,obd1 distibutor,obd0-1 distibutor connector,4wire oxygen sensor and connector,and a obd1 ecu...boomslang and rywire make kits for the conversion </TD></TR></TABLE>
The how toos and what are needed are in the FAQ for doing this.
