Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Those w/ type R rear sway
Old Jul 19, 2002 | 10:34 AM
White Lightnin's Avatar
Default Those w/ type R rear sway
I cant even fit the GSR rear swaybar w/ out my exhaust knocking it. What exhaust do those w/ Type R bar run?
Old Jul 19, 2002 | 10:41 AM
StageOne's Avatar
Default Re: Those w/ type R rear sway (White Lightnin)
Type R exhuast
Old Jul 19, 2002 | 10:51 AM
Default Re: Those w/ type R rear sway (StageOne)
Same reply i got from another guy. Anyone running something else.
Old Jul 19, 2002 | 10:54 AM
ILUVTEC's Avatar
I'm have an original RSR catback exhaust, no rubbing ever, not even real close to it, enjoy
RineRacing's Avatar
Have you checked to see if you mounted the bar upside down? I did when I first installed the bar on my car and it was hitting the exhaust pipe. Then I realized what a fool I was and installed it properly.
Old Jul 19, 2002 | 11:06 AM
Steppin Razor's Avatar
New User
Default Re: Those w/ type R rear sway (Geratol)
My brother has a GSR w/Type R rear bar and Greddy SP exhaust. No knocking
i dont think I mounted it upside down. This is just the dinky GSR sway BTW. The U bracket that holds it to the subframe it what runs dead into the exhaust. im gonna mess w/ it more when I get off of work.
Old Jul 19, 2002 | 11:34 AM
grippgoat's Avatar
I've got a 93 DX Hatch with the stock motor, and in back I have GSR LCAs, and I think it's BSQ's mounting kit (with factory d-brackets and mounting bushings and endlinks), and I haven't noticed any rubbing on my exhaust. Maybe I should double-check.
-Mike
Old Jul 19, 2002 | 11:38 AM
Default Re: Those w/ type R rear sway (grippgoat)
What exhaust do you run. I think it is due to the huge shape of the dunk muffler. much bigger diameter canister than others.
DSMkiller
Apr 7, 2008 01:12 PM
jeddy0120
Dec 13, 2003 09:19 PM
civicmatt
Oct 17, 2002 05:43 PM
SexyTeg
Aug 29, 2002 02:20 PM
